Be right back..........
I think your description is of another system. I'm going to go check your layout first, to make sure. I'll edit this post with in the next 15 minutes to let you know.........
This is what I love most about being a member in the forum, you never stop learning!....
Your right, your fuel pump is mounted seperatly from the carbs. This is the first time I've seen this design. Been working on these motors for over a year and it never ceases to amaze me when I see something new.
Sending PM...........
Here's a test. Since I have to assume the fuel pump is good, because it's new, check to see that your lines are connected correctly. Take off the return line back to the tank, from the pulse line pump. Turn the engine over, you should see fuel spitting out. If so, then put the line on and take the one off going to the carb. Turn the motor over. You should see fuel spitting out to the carb side. If you have no fuel at any of these locations, take off your pulse line from the pump and spin the engine over. With your thumb on the hose, you should feel a pulse pressure.
I've sent you PM, so keep me informed as to what you find out. I'm curious since finding out there is a different configuration in these fuel systems.......
