1998 gtx oil priming
king15012
Messages
26
Likes
1
Water Crafts
1996 gtx 1998 gtx 19 foot open bow
#1
So I replaced the bendix and starter. Ski fires right up now. I bled the oil system. But I don’t remember if I had air bubbles in the smaller supply lines after the oil pump goin to each cylinder. They appear to move with light throttle( towards the cylinders). Is this okay? Normal? Also could I run a premix for the first tank? What’s a good ratio in the tank when also running the oil injection system.
mikidymac
Moderator
Staff member
Moderator
Messages
10,051
Likes
818
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
#2
Premix at 50:1 if you are in doubt of the oil pump. Make sure you open the bleed screw on the pump until clean oil comes out.
king15012
Messages
26
Likes
1
Water Crafts
#3
I got clean oil there. Just seems to always be air in the small lines. That’s why I was unsure if it’s normal?
etemplet
Premium Member
Premium Member
Messages
1,972
Likes
143
Location
Louisiana
Water Crafts
1996 SPI, 1996 GTX, 1997 GTX
#5
Did you replace the oil lines? You could have introduced a little air in the system which should quickly go away once you run the engine a bit. I'd run the premix like Miki suggests. Better to be safe. :)
king15012
Messages
26
Likes
1
Water Crafts
#6
That was my theory, being winter I only fired the ski up for about 10 seconds due to no water. So I could only observe the oil lines move the oil very slowly. I plan to do a proper bleed in the spring( hold the oil pump open at idle). But I think the best option is to do a tank of premix also.
SPONSORED LINKS
Usergroup
