jnssctt@gmail.com
My first jet ski - Just bought a used GTX Ltd. 74 hrs total, 1-owner. Starts well. When sitting at idle you can hear an engine tick or flutter kind of sound. When running wide open, only get 35-37 mph. 1st time out this year.
Any ideas on flutter sound?
Looks like fuel lines are gray. Sounds like I need to at least replace those and clean RAVE valves. If I clean carbs, can you easily do this with engine in ski? Does exhaust need to be removed to get to the carbs? Is there anything easy I can do tot he carbs or should I get the rebuild kits? Closest dealer is an hour away.
Looking for "how to" section. Ideas?
Thanks
Thanks
