neumansmom
Hey everyone, I was hoping to get some clarification on what might be wrong with my 1998 GSX limited ( i believe it is the 951 dual carb motor). I just bought this ski at the beginning of the year, and out of the water it is fine, but after i took it out last weekend, i noticed a white grease was on the inside of the hull. It seemed that it overall was the after mix of the marine oil. I noticed that it was all inside the hull after i realized water was leaking through the drain o-rings. So i was hoping someone might help me isolate where exactly this could be leaking from and how to fix this.
So if anyone could inform me if this is common or any areas to check, I would greatly appreciate it !
Please note that i am very new to jet skis and the placement of all the internals is new to me. I have worked all around car motors, but jet skis are a new thing, so please note that while explaining where i should check.
Thank you!
Thank you!
