The generally accepted way to doo this is to:
Remove the oil injector pump. Remove the teflon drive shaft, that turns it. Cover the hole with a blocking plate.
LEAVE the 2 oil lines that go down under the motor, to lube the rotary gear. LEAVE oil in the injection tank, to service the 2 lines gong down to the rotary gear, and ride.
There are block off plate kits available, although I am not too sure where.
A minor down side to dooing this, is that you will consume MORE oil per hour of riding, than with the injector. (The injector is variable rate, less oil at idle, more at WOT). AND, since you will be running a DIRECT proportion of fuel/oil (usually 40:1, or 50:1) you will consume MORE oil at an idle, with premix, than with the old injection system. This means, that while running at slow speeds, (especially in NO WAKE zones, the oil TENDS to separate out of the fuel, while idling, IN THE CRANKCASE. This built up oil syrup will then have to be burnt off, when you finally to hit the throttle. Thus, you will foul the plugs more often. And, if it was a long NO WAKE zone, then there will be more smoke, when you burn off the excess oil which settles into the crankcase. So, to be safe, I'd be sure to take a few extra spark plugs, and a plug wrench with me, and make some sort of pouch to carry it, without banging them around in the "trunk".
I hope this helps you understand what are the usually accepted trade offs.
If you don't ride NO WAKE very much, or none at all, pre mix will ASSURE you that you are lubing the motor, that is, the up side to pre mix is that you can rest assured that the motor is getting oil.
Sorry so wordy. Too much turkey yesterday!
Nate
