dugedug4
Just picked up a 1997 XP last week, my first jet ski so i'm trying to get up to speed. This forum has been a great help so far so thanks to all contributors.
The first time I put it in the water I had a problem with acceleration, getting to speed very slowly topping out around 30 MPH with power coming and going. After reading through some posts it appears I have the dreaded grey tempo fuel lines so those will be replaced first along with a carb rebuild which I am in the process of doing right now.
After I got the carbs pulled out I look at the bottom of one of them and it appears that gas has been leaking out one corner. It was wet and the paint is peeling off pretty significantly so i'm assuming this may have been a significant portion of my problem. The filters are also filthy so that wasn't helping any either.
Would the leaking be caused by a bad gasket/diaphragm or would you see another problem? At first I thought a piece of the gasket was blown out but it appears that the metal was actually cast without a lip for that corner (normal I assume). Pics attached.
Thanks!
Thanks!
