Plugs are cheap, like $2.50 each. They're right on top, easy as can be to change. Standard spark plug wrench is all that's needed.
Cleaning carbs means removing the throttle and choke cables, also probably replacing the bottom gasket (need to buy online and wait). There are lots of screws and washers. If they haven't been off for a while they could be tough to remove, might strip off a head (happened to me). You're best to have the right sized allen ratchet (I think 8mm? 7mm?), rather than trying to use allen keys. Lots of risk of dropping things irretrievably (in my experience :banghead
under the engine. These bolt styles are hard to find too. Some parts are not even available, I lost the choke lever, it's obsolete and not replaced, so I had to call around a lot. Even worse, dropping something into the intake manifold, you could have a hell of a time getting it out.
Then, when you get the carb off, its bolts could be frozen (mine were), so I had to buy an impact driver. Now carbs have all sorts of tiny bits that the amateur (as you can tell) like me could lose and have trouble figuring out how to reassemble. If you get past all that, wait until you try to re-tension the springs for the throttle and choke levers, and get the oil pump cable correctly re-attached (done by feel alone). I totally tore up my fingers and burned a lot of time with those damn springs. Maybe there's a tool, nobody at my local auto parts store knew of one. If you're a lousy weekend mechanic like me, it's a lot of frustration.
I'd rather work on the drive system, pumps are easy to take off, a lot less parts and if you drop something it falls on the ground, not under the engine.
Of course, if a dirty carb is causing your problem, yes, you should clean, or probably rebuild if you're going to tear the carb apart anyway. I'm just sayin', give new plugs a try. These 2 cycle engines soak the plugs, especially if you're running a little rich they don't seem to last long. Good thing they're cheap.
