1997 Sea-Doo GTX turning over but not starting
I just got a 1997 GTX with 787 motor. It hasn't been run in a few months. It has a newish duralast battery (I have two skis and both batteries will start the other ski). I replaced the starter and the starter solenoid, and now it will sometimes crank/ turn over (usually on the first attempt after charging the battery), but it won't start up. I'm thinking either the gas is bad or the fuel lines are clogged? Also I'm going to clean some of the wires to hopefully get it to crank every time...side note, the ignition key doesn't do the normal two beeps like my other ski, if I hold my head close to it I can hear one very short and quiet beep. I also tried cranking it with the plugs out and no significant amount of oil came out. Any ideas??
