Duckaroo28
I replace the solenoid and the starter 4 months ago put in water ran for 5 min turned it off and wen to start it back nothing it wont do nothing wont crank need help thinking it's the starter are maybe that mpem box
Aftermarket starter? Are you getting 2 beeps and hearing the solenoid or starter click? what's the battery charge look like?
What a gosh website to get the used starter and rebuild kit2 beeps means the key is recognized. After market starters dont tend to last very long best to get a used oem starter and a rebuild kit. Need to make sure battery is fully charged and load test it. It is possible to get a bad new battery
Could you help me need infoWhat a gosh website to get the used starter and rebuild kit
Need help2 beeps means the key is recognized. After market starters dont tend to last very long best to get a used oem starter and a rebuild kit. Need to make sure battery is fully charged and load test it. It is possible to get a bad new battery
Long beepPlease confirm if it is a long beep or a continuous beep as they are quite different causes and solutions.
Roger hard fix you think?Either leaky crank seals or leaky needles/seats or both.
