I've got a 97 GSX that will not turn over by using the start/stop button. I have a new battery for it and it is fully charged. The starter will turn over if the hot wires are jumped across at the solenoid. I have tested the start/stop button according to the service manual, and it checks out good. All three fuses on the MPEM are good and there are 12V on both sides of each fuse. The fuse in the rear electrical box is also good. I have tested the DESS post and it showed good too. The grounds appear to be good and all connections to the MPEM are clean and free of corrosion. I tried checking the plugs for spark while jumping across the starter solenoid leads and there was no spark.
The buzzer was not working so I've replaced it with the radioshack buzzer. Now I still don't get any beeps when I put the key on but I do get one 1 second beep when I hit the start button.
Any ideas?
Any ideas?
