Seadogsx1997
Hi i recently bought a1997 gsx 787 didnt run got it cheap got it home got it running in about an hour took it out had no power and very hard to start on water after it been running so took it off did a compression test mag piston was at 150 and pto at 60 so just did a top end rebuild all good took it out today and started ok started running in was running a bit laggy down low didnt idiol stalled had to keep revs up but was ok at revs brought it in after 15 mins plugs fouled so put new plugs in wpuld start had to lift back of ski out of water to start ran ok up high when took it back out did another 45 mins on it still bad on low revs and want start without cleaning plugs heating up and back of ski out of water good compression on both
