I have a 1997 GSI and I suspect the MPEM is bad. I can't get the engine to turn over using the start switch. I checked the switch and have 0 ohms when pressed. I checked the DESS post and it I get 0 ohms between the black wire and the black/yellow wire with the tether installed and infinite with it removed. I put a wrench across the starter solenoid and can get the engine to turn over that way. I checked the yellow/red wire in the rear electrical box and I'm not getting any voltage when I depress the starter button. The 15A fuse in the rear electrical box is not blown. I discovered that my MPEM has a 15A fuse installed instead of the required 5A fuse and I changed the battery out with an automotive battery while letting the original charge (I think this may have fried my MPEM). I don't know what else to check. I have discovered that my MPEM (part number 278000928) is very hard to find. Could I just use an MPEM (part number 278000916) and not plug in the connector that feeds the gauges? Oh and I know I have a bad beeper that I have yet to replace so I can't listen to the 8 beeps to tell me the MPEM is bad. Any other assistance on using other MPEMs or further troubleshooting would be very helpful. Thanks
