Shop Discount Sea-Doo Parts
1997 Challenger single 787 - Garden Hose Connection Location?
easygoin4
Messages
33
Water Crafts
challenger, lrv, xp
I have 3 fittings on my boat, 2 in rear at transom, not in pump area, and 1 under the hood near gas tank filler.
I just finished putting the engine back together and want to run for a bit, but need to have water running thru it.
There is a garden hose connection up near gas tank filler that looks like it threads on, also couple fittings at transom.
Which do I use and what are they all for?
I do believe I have to start engine before turning on hose, and turn off hose before shutting down engine.
Do I need full pressure from house for garden hose.
Thanks in Advance..
easygoin4
Messages
33
Water Crafts
challenger, lrv, xp
Looking at my parts manual it appears that one of the fittings at transom is from the Bilge.
However the other and the one at gas filler are appear to be the same style.
Is one for flushing, after ocean riding and the other for garden hose to run out of the water?
Thanks
enut
Messages
173
Location
Liverpool, NY
Water Crafts
2008 Seadoo Utopia 205, Sold: 1998 Seadoo Challenger 1800
The one that is on top that is covered by the engine hatch is the one to put the hose on.
Also, it should have a screw on cover that is tethered by a chain.
easygoin4
Messages
33
Water Crafts
challenger, lrv, xp
Yes it does have a cover with tether.
I have seen videos of hose connections at transoms on jet skis, so was not sure.
Thanks
Any idea why the other at the transom..
enut
Messages
173
Location
Liverpool, NY
Water Crafts
If you have a service manual, they explain that it exhausts water out during normal operation.
You can connect to it as well but it is much easier to connect it on top. When I had my boat, I plugged this when I connected the hose to the top. Just make sure you remove it after you are done.
Steve762us
Messages
76
Location
GA
I screwed a garden hose ball-valve shutoff onto the transom
fitting. Close the transom fitting when flushing on hose
(with hose on upper fitting, near gas cap), open the transom
fitting when running boat on water (as in river, lake, ocean
water!).
If you leave the transom fitting closed when "driving",
it will short-circuit some of the cooling passages and cause overheating.
SPONSORED LINKS
Usergroup
