twothxtrm
Hey guys! I'm working on a new to me 1996 refresh.... It would appear that there is a flush port already installed but seems to be on the exit side of the system. Can I use this port to flush or should I install on the intake side? Also, from the pics can you tell if someone reversed my flow? I read that this is common. From what I can tell the flow seems to be correct?
Also, I will need to replace the throttle cable, any tips or ticks that you guys might have?
Yes, fuel lines are on the list. Looks like the ones feeding the carbs have been replace and are behind a filter from the PO. I will go ahead and replace all. Black line of clear from Blowison?
Cosmetic progress on the refresh...
