I recently purchased this XP knowing it had the injection delete. What I did not realize is that PO removed all lines to the rotary valve. I have located brass plugs where the nipples should be. I am hoping they have a trapped volume of oil in there but have yet to pull the plug under the carbs to find out as I am still fixing it's other challenges.
When I get the plug out and drain it, should I be filling the cavity nearly full, (xp propped up on it's side) or what is reccommended?
To me this does not seem like a very good solution as it is very akward to maintain which means it will probably get ignored too long. If I could find a complete injection system close to home, (getting tired of stupid high shipping prices from the US) I would really consider taking it back to the way the system was designed.
