It's super way easier to turn those screws, then checking pop off, (you have to remove the carbs, disassemble them, get or make a pop off gauge, find the thread,etc..)...first, turn the screw in till it is seated, keeping track of how many turns, it will be about 1 or so full turns, you can google the exact number. Then turn out the screw 1/4 turns out more. And of course do the same to the other one.
Either way, this is a temporary fix, since it indicates your carb is not getting its stock factory setting, and that you need to go thru the carbs. (Or fuel delivery system starting at the fuel pick up ).Hope this helps you get started,
