LOOSE electrical connections...not LOSE connections....23 year old ski, she needs love and attention...check everything for loose connections, rust, corrosion, etc....1 dess post is fine
2 it doesnt loose electrical connection either (or so i think) it just dies down and doesnt want to rev up again and then dies completly
3 its not wanting to fire? i think its the weak spark that does this. buy a new coil?
Quickly and simply (and I believe this info to be fairly accurate).....there is a pickup coil inside the engine cover that is getting a signal from the stator...that signal gets to the ignition coil (in the rear electric box - typically on a white wire) to fire the spark plugs. I have been informed that BOTH spark plugs fire simultaneously (a wasted spark system).I changed spark plug boots then it got a little better but i still thinks its pretty weak. Also worth mentioning is that when i go full throttle it goes maybe half throttle then all of the sudden full power comes after a bit. Carburetor? Or could it still be weak spark?
Since you say that the ski does run, albeit with shutoff issues, you are moving away from the spark/ignition coil as a potential problem candidate (BUT not entirely...there could still be issues there, of course)....you also state that the ski is "bogging" on the throttle....THAT typically puts us into the carbs.
Everything really has to be working in sync....fuel, spark, etc...for these machines to perform well and consistently....they ARE labors of love sometimes....frustrating OFTEN!
