I had the same issue the other day, and MINNE kinda has the right idea....he uses SOLID TIP SPARK PLUGS now, cuz he had the same problem...not saying this IS your issue, but its a cheap, quick way to see if thats your problem..
Mine was momentarily cutting out for a second or two during WOT or almost WOT, I got home, took the boots off the plugs, and sure enough, those screw on tips were loose, wiggling around, and almost completely off...tightened the caps ALL the WAY, and haven't had the same problem since..
Funny thing is, i drive pretty far to get spark plugs, cuz the last time i got some, the store 2 minutes away from me ONLY had the solid tip ones, and i passed on them....
Well now at least i know that those are the ones im gonna wanna get...
P.S.,
I also, did the whole "cut a 1/4" off the spark plug wire ends, then put boots back on with new tight zipt ties", so maybe that contributed to my fix as well, but this is something you MAY wanna check out and consider...
PROPS TO MINNETONKA4ME on this one...
