Runs but loses power and/or spark when the throttle is engaged... i used a spark plug tester and on idle it seems ok but when you rev it up the spark cuts out and it bogs... any ideas?.. thanks alot..
MMMMMMMMMMMMMm
Have a look at the fuel lines 1st.If they are grey.They need changing.There is more threads on here about grey fuel lines than anything.Then to follow.Carb filters,etcThe lines may be clogged resulting in lean fuel and/or a blowup.Look at this 1st and come back in the pwc2 stroke section please.I noticed you are a newer member so this is the best way to help you.Thanks
