1996 spx 657 wont run
babsfarms
hey there i am new here i have a seadoo spx and i just put new pistons and seal kit in it and it wont stay running will run for 5 seconds then quit and the plugs are covered in gas. the carb on stator side throws gas out the top but the pto side doesnt but yet the plugs are all gas if someone has some input that would be great and the compression is 150 on each side thanks!
Welcome to the forum. You haven't mentioned if any work has been done to the carbs. Have the fuel lines been changed out? Carbs recently cleaned? Was anything done with the rotary valve plate when rebuilding the top end?
Try posting this in the 2-stroke PWC section of the forum. The people there will be able to address your issues for you.
