1996 Seadoo SP dies if I try to accellerate-acts like it is starving for gas. The problem started out with it bogging down at higher rpm until you let off the throttle, then it would run OK at a lower rpm. The problem got progressively worse until it would only run at idle speed. If you give it some throttle it would die unless you let off the throttle. I checked the fuel filter, ran carb cleaner through it but didn't help. I had a mechanic who has a mobile maintenance service come look at it. He put his tester on it and said it's an electronic problem. I still think it's a fuel problem, but I'm no expert. Anyone have any ideas? Thanks, Larry
