Hi all.
I am considering buying a 1996 gtx from a friend. I have ridden this several times and every time there is this minor problem.
When you get up to about 4000 rpm, and keep gently applying throttle, it will at some point rapidly accelerate up to 5000 + rpm.
The owner says that that is the second jet in the carb kicking in. He says nothing can be done about it. But as it is, there is about a 10 mph range that you can't go. You are either going below, or above, depending if the second jet has kicked in or not.
Is this a fixable issue? What can be done, if anything.
Thanks for your help.
paul
paul
