Shop Discount Sea-Doo Parts
1996 GTX limp mode?!
SEA-MONSTER
Messages
114
Location
MERRICK, LONG ISLAND NEW YORK
Water Crafts
1996 GTX
1996 XP
1995 Explorer (RIB)
1989 Wellcraft V20 305 sbc
Hello, when I tried to use my GTX this weekend, 1st time this summer, it starts right up (new battery) idles fine sounds smooth, ect.... when I go to throttle it, it revs up normally for about 10 seconds the dies down to about 3500 rpms, it dose not stall just dies into a limp mode, if I turn it off then restart the same thing. I feel its electrical, its to exact to be a carb problem, yes I maintain it well, new fuel lines and all, had it for a # of years, motor been rebuilt 3 years ago and still has solid compression, (147 & 148psig) any ideas what to try 1st?! Any help would be appreciated.
LouDoo
Premium Member
Premium Member
Messages
12,673
Location
Lexington, KY
Water Crafts
SeaDoo's: 96 GTI 720, 95 XP 800 Limited, 96 GSX 787. 2000, 18' Bayliner 3.0L.
The first thing I would check is the rectifier/voltage regulator. Disconnect the red lead and see if the problem goes away. When you disconnect the red lead your ski won't charge the battery, so if this fixes the problem you need a new rectifier, and I would highly recommend an OEM. BTW your ski does not have a limp mode.
Lou
SEA-MONSTER
Messages
114
Location
Water Crafts
1996 GTX
1996 XP
1995 Explorer (RIB)
Escaped from work a little early today, hooked up a volt meter to the Gtx on the drive way, started it revved it to about 4500 rpms and when the voltage got to 16.5, it bogged down, I just ordered a rectifier, hopefully this problem will be fixed!
Matt Braley
Premium Member
Premium Member
Messages
7,055
Location
Niceville, Fl
Water Crafts
I can't keep up with it anymore. I've got some really cool skis!!
It will be Lou was right. It happens all the time on 96 787's.
SPONSORED LINKS
Usergroup
