freshforest
Hi starting to pull my hair out here hopefully somebody can help.. OK I've been over the boat cleaned the raves. Just had a local shop re-jet and set up the carbs (was told all is good in carb land) brand new, pump oil, impeller, pump bearings, wear ring. I checked the fuel selector valve which also looked great, the fuel lines are black rubber, fuel filter is clean.
Ok on take off the engine revs right to 7200 rpms the boat comes out of the hole just fine and starts to plane. (engine sounds good) once the boat comes up on plane the rpms drop to about 5300 rpm then gradually they will build to 5400 rpm then it stays there. If I let the boat lose speed once it sits back in the water suddenly the rpms will go to 7200 again the boat will plane then back to 5300 rpm and over and over and over. If I leave it w.o.t it runs fine just 5400 rpm.
It did this before I had the carbs looked at
Im stumped and I just want out on the river, any ideas would be great!!
