zperez2012
Hey guys new to the forum . Recently got a 96 challenger with the 787 rotax . Seemed to run like a top , it has been oil injection deleted as well. Well I took it out on the water this weekend and had some problems . I was cruising through the no wake zone in the river and once I got to the main stretch I got on it wide open . Boat got up to around 44 just cruising then out of no where started cutting out and bogging down . Ended up getting towed back to the boat ramp because it wouldn’t start up. Pulled the plugs and they were oil/gas covered . I mix it at 40:1 and had just put fresh gas and plugs in it . I did use synthetic blend two stroke oil and not the brp yellow bottle . Could this be the problem . I’ve done some research and I think maybe the low speed or high speed on the carbs are too rich and maybe rave valves need cleaning . What really has me confused is when I got home I did a compression test (harbor freight gauge ) and both cylinders were low but even 105 psi on each . Put the plugs back in and it fired and reverse great ? Any advice welcome thanks
