Cheflen
So I just took my 95 sp out for the first time today after rebuilding everything on it. (The budget 95 sp build) I went through the entire break in procedure throughout the day, and the ski is running absolutely great now, tons of power, great throttle response, etc. one concern, when I had it in the water for about 45 minutes it started having issues starting, once it started it drove perfectly. The biggest factor that I think is playing is that the water temps are probably around 38 degrees, I live in Illinois and it was literally snowing a week ago. But the air temps were mid 60s. It also had the same starting issue on the trailer as soon as I pulled it out of the water. But I waited about 5 hours of it being out of the water and it fired right up on the first crank again. Is this because of the cold water temps? Do I need carb adjustments? Jetting? Another thing, it was still hard to start in the water even when it was warmed up. Thanks for the help in advance.
