1995 seadoo xp
Tlccleaveland
Will crank over but will not start check for spark guess getting spark put gas in carburetor still will not start notice there is no beep now with the key put on any ideas what could be causing this
Check battery voltage,,,should be around 12.6V and then load test the battery,,I have had numerous occasions that no "beep beep" ,,,the battery was weak,,,got the voltage up to snuff,,,and voila ,,,beep beep,,,a weak battery can also produce a weak spark
