Hello, I have a 1995 spx and it runs fine but if you come out of the water while riding it, it quits and you have to disconnect the power and reconnect it for it to start again. Can't figure it out. Need some help. Thanks.
Sounds like you aren’t getting good connection between the key and the dess post. Clean the post thoroughly with soap and water. Also check all grounds. Main ground to starter and small grounds in ebox .
Sorry missed the 95 part. Still sounds like a bad connection. Check all connectors and grounds. Also make sure your key is holding the plunger down all the way.
