so last fall I found out that the pistons and rings got a little cooked on our last trip out. so I rebuilt the carbs because I'm pretty sure that's what cooked the pistons and rings and I also bought a piston and ring kit with all the gaskets and today I finally got a chance to get it put back together. everything went back together great after I got everything cleaned up including all the threads. fired it up and it runs great but it seems to be leaking exhaust between the head and exhaust manifold. I used new gaskets that seemed fine and I know that all the mating surfaces were completely clean. is this a normal issue after top end rebuild that goes away after a good heat cycle?
