XPARIZONA
94 XP with VTS, so the trim wasnt working, common problem on older ski, ill go down the entire list in order of what i did,,,,
first checked motor, its fine, works good, just not with switch,
so i checked fuse, fuse was good,
then checked switch, switch was good,
so i figured module was burnt out, so...
replaced module with good one, still not working, checked output of module with engine running, and when you hit vts switch up or down it has 12v coming out on the up or down side of the plug,but plugged in it does not function,,its as if it loses its ground when plugged in and its not able to isolate from one side to the other, if i ground one side, the other side works, and if flipped around same thing,,cant figure this one Anyone??
