Electronics have nothing to do with the baffle's ability to send fuel. There is a fuel level sending unit built into the baffle, but I'm not sure if your ski came with that. The baffle has two pickup tubes (ON and Reserve), a vent and a fuel return attachment. They are all 1/4" barbs. Have you checked that your fuel selector knob is pointed to ON or RES? Are you sure the knob is not stripped? You can remove the selector and plumb the intake directly to the RES barb on your baffle. It should pickup fuel right away. Some early models (1992 for sure) had a baffle that used rubber hoses attached to metal filter screens. These would rot away and break off, leaving only a short length of pick-up tube. I believe the 1994 had the plastic tube baffles, where this was not an issue, especially if you have the sending unit wires coming out of it. If you're still not getting fuel after bypassing the fuel selector, pull the baffle and inspect it. Also, make sure you have the fuel/water separator screwed on properly. If that leaks enough air, it'll not pull any fuel.
