Strange issue.
I have a 1992 XP 587 white with the following.
• Rebuilt Carbs (Mikuni Kits)
• New Solenoid
• New Rings (honed cylinders; 140 compression on both)
• New top end gasket kit
• New Exhaust gaskets
• New Battery
• Black Fuel lines (No Grey Tempo)
• Inline clear fuel filter
• Fresh Gas (Premix)
The ski is new to me and did not run when I got it. After putting on the new rings I put it in the water and it ran but would hesitate and only run for about 45 seconds. I determined the carbs needed to be rebuilt. Got both carbs rebuilt and set proper pop off pressure (if I recall just under 30psi); started with the high speed set to 0 and the low speed set to 1 ¼. I put it in the water and it ran good with only a little hesitation at WOT. After riding for a little bit I stopped for lunch, went back to the ski and it won’t fire. It will turn over, has spark (plugs are milk chocolate in color not wet), I pulled the fuel line where it comes out of the mag and into the PTO carb, it pulses fuel. Would not start….
But when I put it on the trailer and try to start it, it spits water out of the exhaust and fires right up. I went back a few days later and put it in the water and it ran well (not great). After about 45 minutes I shut it off again and it won’t start. Put it back on the trailer and it fires right up. While running on the trailer if I cover the exhaust port with my hand it does not take much to kill the engine. When the ski won’t start and I pull the plugs they are dry and chocolate in color; visibly the spark is hard to see but have an inline light that indicates the coil is firing. I have tried two sets of plugs; both relatively new. Not sure if it is common but at times there will be smoke from the exhaust in the engine compartment
• New Solenoid
• New Battery
