I picked this old doo off of craigslist with the intention to tinker and see if i could get it going again... I havent been twiddling my thumbs, i'll run you through what I've accomplished already.
First and foremost I emptied the gas tank and the oil tank and refilled with new gas/oil.
I tested compression in both cylinders, 125 for both (I think thats ok? yes?)
I checked for spark *check*
I checked for fuel, Negative... I cleaned out the fuel selector and mech fuel pump/filter.. Doo now has plenty of fuel flowing to the carb *check*
I reset the low speed oil mix adjuster to two turns out, I could not find the default setting the the idle adjustment screw or the high speed adjuster mix.. also there is a screw with a spring around it under the high speed adjuster that i have not been able to find any info on the forum as to what it is/does.
now that all the basics have been covered (I think)
Upon trying to start it the carb backfires from the air intake (small burst of flame) every few seconds
now is where i've hit a deadpoint, I realllllllly don't want to take apart the carb... but it has been sitting for some years....
Any help/ideas will be much appreciated!!!
