Shop Discount Sea-Doo Parts
185 SuperCharger is Same Specs Of A 215 Supercharger
Messages
44
Location
Atlanta Falcons
Water Crafts
2005 RXT-215
2004 GTX-185
Have a 2004 GTX SC-185 That The SuperCharger was Rebuilt and A 2005 RXT-215 Supercharger That Need Supercharger Rebuilt, So Can I Put In The 185 SuperCharger Into The RXT-215 Doo.
Messages
44
Location
Atlanta Falcons
Water Crafts
2005 RXT-215
2004 GTX-185
Ok, Thanks,
My 2004 GTX-185 Lock-Up, I just pull The Valve Cover There Is A Broken Rocker-Arm On Middle Cylinder on Exhaust Side What Would Cause the Failure With Out Opening The Motor Up.
Messages
44
Location
Atlanta Falcons
Water Crafts
2005 RXT-215
2004 GTX-185
Timing Chain Is Not Broken and Spark Plug Itself Has Been Crush On The Tip, Maybe The Piston Hit It Or Valve Drop, So I May Have To Take It Apart To Tell The Cause.
Messages
44
Location
Atlanta Falcons
Water Crafts
2005 RXT-215
2004 GTX-185
Had some time, I pull the 185-Motor remove the head the middle piston is gone and crack case, anybody have an idea what happen first in the piston destruction, so im looking for 185 or 215 motor.IMG_7484.JPGIMG_7489.JPG
etemplet
Premium Member
Premium Member
Messages
2,756
Location
Louisiana
Water Crafts
1996 SPI, 1996 GTX, 1997 GTX
That's Scary!! What the hell would cause that on only one cylinder?? Timing ? How much are engines for these skis? $3K?
Messages
44
Location
Atlanta Falcons
Water Crafts
2005 RXT-215
2004 GTX-185
Now I`ve Learn that whoever rebuild the motor put a N/A block with High Compression Piston on top with the stock SuperCharger and Boomm there goes a Piston, $2500 to $3200.1123191809a.jpg
This was the Center Piston
etemplet
Premium Member
Premium Member
Messages
2,756
Location
Louisiana
Water Crafts
Day-Yum !!! That"s Ugly !! Could the supercharger put water into the engine? Seems to be only one cylinder on the engines. Wrong pistons all around should show varying degrees of failure, I would think. :D
Users who viewed this discussion (Total:11)
SPONSORED LINKS
Usergroup
