hello everyone
I am a new member to the forum. I just picked up a 02 rx with 75 hours on it. compression is spot on at 135 . The seller claimed that it has always been dealer serviced. I have never owned any other pwc , but i have alot of experience doing my own maintenance on my mercruiser IO. so i want to start with a baseline on the maintenance on this machine. I am planning on pulling the rave valves and cleaning them. do i need to order any of the o rings when i do this job ? the next thing that i want to do is replace the oil injection system filter. it looks like i need to remove the exhaust pipe to reach the filter and purge the air from the oil pump. do i need to replace any of the gaskets on the pipe,and do i need that special wrench to reach the bolts. thank you for your help and let me know if there is anything else i should do . the fuel lines have already been replaced from the factory grey lines
