Spare Spark Plugs - Seadoo Forums
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 23 of 23
  1. ☑ ORIGINAL POSTER #1
    Junior Member PJ Moran's Avatar
    Join Date
    Oct 2017
    Location
    Texas
    Posts
    14
    Watercrafts
    2006 Sea Doo GTI SE (x2)
    Thumbs Up
    Received: 0 Given: 0
    Default Spare Spark Plugs
    Sea Doo went to the trouble of including holders for three spare spark plugs in the lid of the cargo compartment. Why did they do that? Who thinks it's necessary to carry spare plugs with them and why? Even the tool kit has a plug "wrench" (heaven forbid I should ever have to use it ). This all implies that it's not uncommon for plugs to go bad while on the water. Should I stow spare plugs on my rigs?
    0 Not allowed!
  2. # ADS
  3. #2
    racerxxx's Avatar
    Join Date
    Aug 2012
    Location
    Chalfont, Pennsylvania
    Posts
    9,963
    Watercrafts
    89 SP, 91 XP,(2) 96 XP's, 99 Speedster Twin 800's , 95 HX, 95 XP800, 98 SPX
    Thumbs Up
    Received: 522 Given: 81
    Default
    Probably a carry over idea from the 2 stroke days. But I will say I've seen many guys come here looking for help in running issues and plugs fixed them up. It's cheap insurance, would you rather limp home or cruise home?
    0 Not allowed!
  4. #3
    SeadooForum Hall of fame ski-d00's Avatar
    Join Date
    Apr 2009
    Location
    St. Marys, Ohio
    Posts
    2,122
    Watercrafts
    2012 RXPX 2012 GTR 215 2006 3D DI 2005 Speedster 200 SC 370HP
    Thumbs Up
    Received: 83 Given: 1
    Default
    It is a misconception that the 4tecs do NOT foul plugs. Even though these are 4 strokes, they don't act like the plugs in your car that will last 100,000 miles. I've seen plugs foul just a few minutes after installed. Not a bad idea to use the holder and carry plugs with you.
    0 Not allowed!
  5. #4
    SeadooForum Hall of fame Sportster-2001-951C-Stock's Avatar
    Join Date
    Jun 2013
    Location
    Virginia Sea Level
    Posts
    7,000
    Watercrafts
    2001 Sportster LE 951 Carbed
    Thumbs Up
    Received: 287 Given: 47
    Default
    This extra set of plugs can get you going again if you happen to water foul your plugs. To avoid engine damage, stop running if the engine isn't making power like it should b/c damage can result.
    Make sure to always run the factory recommended correct plug for your engine b/c the incorrect plug generally won't run correctly or cause damage (pre-ignition, for instance). Change them immediately if one does foul or avoid running the engine.
    Go hunting where the ducks are.
    0 Not allowed!
  6. #5
    Join Date
    Jun 2017
    Location
    Ontario Canada
    Posts
    49
    Watercrafts
    2 - 2007 GTX 4-tec 155 HP Yamaha SX-210 Jet Boat 2 x 110 HP
    Thumbs Up
    Received: 1 Given: 0
    Default
    If I remember a plug change on a 4 tec is not required till 200 hours, in the brp shop manual.
    0 Not allowed!
  7. #6
    racerxxx's Avatar
    Join Date
    Aug 2012
    Location
    Posts
    9,963
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by JTR View Post
    Same as a supercharger........how close to the 200 hours do you get? Most guys do it well before the 3 years or 200 hours.
    0 Not allowed!
  8. #7
    Experienced Rider
    Join Date
    Mar 2008
    Location
    Pensacola, FL
    Posts
    335
    Watercrafts
    1995 XP (sold) 1999 GTX Limited (sold) 2X 2002 GTX 4-tec
    Thumbs Up
    Received: 22 Given: 17
    Default
    My old 95 XP went through plugs, like Patton used to say, like CR@P through a goose. On my 4-tecs, I always change them at the end of the season, and I have never had to change them during the riding season.
    0 Not allowed!
  9. #8
    Join Date
    Jun 2017
    Location
    Ontario Canada
    Posts
    49
    Watercrafts
    Thumbs Up
    Default
    It seems different now too with some car engines, at least 100,000 kms before plug change.
    0 Not allowed!
  10. #9
    Join Date
    Jun 2013
    Location
    Virginia Sea Level
    Posts
    7,000
    Watercrafts
    Thumbs Up
    Default
    Considering the difference in how a car engine is operated vs a marine engine, I think that helps explain why any marine engine MIGHT need the plugs changed more often due to fouling.
    Therefore "mileage may vary" is a reasonable conclusion, right? Gotta say based on the precision of fuel injection, I could easily imagine 4-tec plugs exceeding 200hrs by a wide margin, just as a modern outboard can clock over 8k hours.
    0 Not allowed!
  11. #10
    Join Date
    Jun 2017
    Location
    Ontario Canada
    Posts
    49
    Watercrafts
    Thumbs Up
    Default
    I tend to disagree, I could maybe believe that because the Rotax RPM is run in the 7000 and it could wear the plugs quicker. But the 4 stroke fuel injected engine is the same whether car or marine. Imho it would be difficult under normal operation to foul the plugs, air/fuel is always adjusted by the cpu. If plugs are fouling it's another problem. I would check the gap and adjust.
    0 Not allowed!
  12. #11
    Join Date
    Jun 2017
    Location
    Ontario Canada
    Posts
    49
    Watercrafts
    Thumbs Up
    Default
    Forgot to mention 200 hours is equivalent to 12,000 miles. 60 x 200
    0 Not allowed!
  13. #12
    Join Date
    Jun 2013
    Location
    Virginia Sea Level
    Posts
    7,000
    Watercrafts
    Thumbs Up
    Default
    And the operating conditions present challenges that add complexity. Lack of maintenance can be a biggie ("it's another problem").
    Not just Rotax turning at 7,000 RPM, it's the marine environment. Lots of things can happen. For example, lets say you hit a wake and flipped upside down briefly and some crankcase oil vents through to the intake, enters the cylinder and glazes onto the hot plug insulator causing contamination? Or the ski sits around for a little too long and the fuel gets a little stale or water, and glazes the insulator during a hard run your average car is unlikely to experience. Who are that nobody that rides WOT across the lake like there's no tomorrow, does he drive his car that way too? I doubt it, thus the root cause might even be the nut behind the wheel.
    Please don't claim it's a car, this is misleading b/c generally speaking, a marinized engine runs with a more conservative tune using a colder plug than automotive engines, less aggressive ignition timing and a richer air/fuel mixture because the marine environment is considerably (not slightly) harsher in comparison. Marine engines are burning a heck of a lot more fuel (measured in GPH as opposed to MPG) than an automobile engine loafing down the highway @ 1800 RPM. This translates to considerably more heat.
    High duty cycle with no coasting up to stop lights or down hills, on and on.
    The marine engine is a beefed up version in comparison and the 4-tec as far as I know doesn't benefit from an O2 sensor in the exhaust (it's a wet exhaust) as used by automotive computers to monitor air/fuel stoichiometry. For marine FI engines at least up until recently, there's just a simple lookup table used to produce a conservative air/fuel ratio approximation based on throttle angle, RPM and intake manifold vacuum + added safety of slightly richer mixture to compensate for (un?)anticipated harsh conditions.
    So on top of high power requirements, burning one heck of a lot more fuel and as a result making a heck of a lot more heat, the air/fuel ratio is considerably richer for the purpose of maintaining a reasonable safety factor.
    Add this all up, and 200 hours reasonably represents IMO, an accomplishment.
    0 Not allowed!
  14. #13
    Experienced Rider Hawk388's Avatar
    Join Date
    Apr 2016
    Location
    Santa Rosa Beach, FL
    Posts
    259
    Watercrafts
    2016 GTR 215
    Thumbs Up
    Received: 21 Given: 13
    Default
    Quote Originally Posted by PJ Moran View Post
    Actually, it implies that people will do stupid shit and without further advice, try to start their machines after they've rolled them in surf. For crying out loud, the damned plugs are there for a reason as is the wrench. If you roll your shit, pull the damned plugs, turn it over and see if water shoots out. If not, resue your old plugs. If so, use the new ones. Ignorance IS NOT a reason to be a dick.
    0 Not allowed!
  15. #14
    SeadooForum Hall of fame jhjesse's Avatar
    Join Date
    Jul 2009
    Location
    georgia
    Posts
    2,309
    Watercrafts
    2000 GTXDI 2002 RXDI 2009 RXTIS Two 2001 GTXDI's
    Thumbs Up
    Received: 68 Given: 27
    Default
    Reminds me of some of the great oil debates we’ve had on the forum over the years.
    Enjoy life, jet ski "BIGLY"
    0 Not allowed!
  16. #15
    Join Date
    Jan 2011
    Location
    Tampa
    Posts
    229
    Thumbs Up
    Received: 24 Given: 0
    Default
    If you think spark plugs are not an issue with 4TECs, then you don't know much about them. If the ski is running fine on the water, however, it is rare they go bad. The usual time they fail is after dewinterizing or just after sitting for a long time.
    My lake house is a quarter mile from the main ramp. Every summer I have guys stopping in front of my house because their ski is running like sh1t. One time I told a guy his plugs were bad. He said " I am a mechanic, plugs don't go bad like this" He was pissed and being a prick. I told him I bet him $100 it was the plugs. He said OK smart guy, you have a bet. I went to the garage, grabbed three new plugs and tools and returned to the dock. 5 minutes later, he started it up, took off, it ran perfect, and I was surprised he actually came back. He looked embarrassed, but took out his wallet. I told him to just pay me for the plugs. Gave me 50 bucks as he said I saved his day on the water
    0 Not allowed!
  17. #16
    Join Date
    Jun 2013
    Location
    Virginia Sea Level
    Posts
    7,000
    Watercrafts
    Thumbs Up
    Default
    Sounds like the kind of mechanic who'd rebuild a motor twice, for the same seized cylinder.
    0 Not allowed!
  18. #17
    Junior Member
    Join Date
    Oct 2016
    Location
    Louisiana
    Posts
    17
    Watercrafts
    2016 Sea Doo RXT X 300
    Thumbs Up
    Received: 1 Given: 2
    Default
    the spark plug change on a 1503 is 200 hours but on a 1630 it is 100 hours.
    0 Not allowed!
  19. #18
    Join Date
    Jan 2011
    Location
    Tampa
    Posts
    229
    Thumbs Up
    Default
    Quote Originally Posted by Sportster-2001-951C-Stock View Post
    No, he was an auto mechanic. Plugs on cars these days last 100K miles, they almost never go bad, so he was comparing a ski to a car. His ski was relatively new, so he thought there was no way the plugs could be bad.
    It is common for 4TEC plugs to go bad every season, usually from fogging.
    0 Not allowed!
  20. #19
    Join Date
    Jan 2011
    Location
    Tampa
    Posts
    229
    Thumbs Up
    1 out of 1 members found this post helpful.
    Default
    Quote Originally Posted by smkas26 View Post
    Those numbers don't mean a thing, those are just Sea Doo recommended numbers. Again, these numbers make people think the plugs are a rarely replaced item, when it is not true. They fail all the time.
    0 Not allowed!
  21. #20
    Join Date
    Jun 2017
    Location
    Ontario Canada
    Posts
    49
    Watercrafts
    Thumbs Up
    Default
    Sorry do not agree, they rarely fail. It is another problem that affects the plug, not the plug itself. Plugs can last forever, if the gap is increased by wear, just regap. So much $$ wasted on replacing good parts.
    0 Not allowed!
  22. #21
    Chester's Avatar
    Join Date
    Nov 2008
    Location
    Langley, BC Canada
    Posts
    1,352
    Watercrafts
    98 SXi Pro
    Thumbs Up
    Received: 15 Given: 15
    Default
    I fix them for a living and I see them foul several times a year on different customers PWCs. It doesn't matter if it's a Jet-Ski, WaveRunner, or Sea-Doo, it happens on all brands.
    I just tell them to replace them annually, they're cheap.
    Chester
    If you can't afford to do it right, how will you afford to do it over?
    0 Not allowed!
  23. #22
    Junior Member
    Join Date
    Oct 2016
    Location
    Louisiana
    Posts
    17
    Watercrafts
    Thumbs Up
    Default
    I was showing what Sea Doo Recommended to clarify a earlier post showing 200 hours on a 4tec . I put 100 hrs a year on a ski as do most of my friends, so on my 300 thats new plugs at least once a year. Of course I am lucky enough to be able to ride most of the year and never winterize.
    0 Not allowed!
  24. #23
    Join Date
    Jun 2013
    Location
    Virginia Sea Level
    Posts
    7,000
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by Sea Dood View Post
    At least he won't be working on my boat. Assuming a 4-tec burns ~8GPH that's equivalent to driving the 24MPG family sedan about 190MPH Of course the plugs will foul more often but that would be the least of worries.
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Removing the spark plugs in a Spark
    By RedDuck in forum Sea-Doo Spark Forum
    Last Post: 09-29-14, 04:13 PM
  2. How to test spark plugs if they spark?
    By prd in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 08-25-14, 04:40 PM
  3. GTI 130 Spark plugs, Do fancy plugs make a difference?
    By Freddyk79 in forum 4-Tec Sea-Doo PWC Forum
    Last Post: 09-11-13, 01:52 PM
  4. No Spark to plugs 94 GTX Help me out!
    By mhicks in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 09-23-08, 01:22 PM
  5. How do I verify spark at spark plugs?
    By ctech82 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-26-08, 03:53 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
