Sea Doo Islandia 2008 Radio question - Seadoo Forums
Visit PWCMuscle.com
for 15% off all Hydro Turf - CODE: HYDRO15
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 3 of 3
  1. ☑ ORIGINAL POSTER #1
    Join Date
    Sep 2012
    Location
    Avon Lake
    Posts
    2
    Watercrafts
    2009 Sea Doo Islandia 1996 Sea Doo GTX
    Thumbs Up
    Received: 0 Given: 1
    Default Sea Doo Islandia 2008 Radio question
    I am in the process of swapping the factory installed Jensen marine radio-
    The new Kenwood stereo - all wires match up on the new harness except the yellow battery
    12V - which the original harness doesn't have the yellow 12V with in line fuse- on it-
    Not sure where to get this power from? Any suggestions
    0 Not allowed!
  2. # ADS
  3. #2
    Junior Member DooGuy's Avatar
    Join Date
    Feb 2016
    Location
    Spokane, Wa
    Posts
    20
    Watercrafts
    2007 Sea Doo 230 Challenger Se
    Thumbs Up
    Received: 1 Given: 2
    Default
    I know in a car, Yellow is usually a battery line. In the wiring it looks like orange may be your battery. Before connecting I would use a volt meter and check with battery switch on/off. Here are the schematic from a challenger but should be similar.IMG_7308.JPGIMG_7307.JPG
    1 Not allowed!
  4. #3
    Member slaizer2000's Avatar
    Join Date
    Jul 2016
    Location
    Rochester, NY
    Posts
    43
    Watercrafts
    2007 Seadoo Islandia SE
    Thumbs Up
    Received: 1 Given: 9
    Default
    I just installed a bluetooth adapter on my Islandia 2007. It has a clarion radio though. Unsure if it was stock or aftermarket as I bought the boat used.
    Black ground = black, Orange 12v = yellow, Red 12v switch (radio cut off switch on dash) = red. I've attached 2 Pics of what wire is which.
    The black and yellow wires are on the adapter harness were pretty thick and easy to pick out. The red one was thinner so it wasn't as easy to identify.
    Hope it helps out. I did have to measure the volts as I wanted to tie the bluetooth adapter in to the radio cut off switch vs always on.
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Replies: 1
    Last Post: 04-28-17, 08:51 PM
  2. 08 challenger radio question
    By Albysure in forum 4-Tec Sea-Doo Boats
    Last Post: 06-17-14, 03:21 PM
  3. Challenger 180 radio question
    By Craigmri in forum 4-Tec Sea-Doo Boats
    Last Post: 09-24-12, 04:57 PM
  4. RXT-X Radio / Regulator Question
    By cmiiller in forum 4-Tec Sea-Doo PWC Forum
    Last Post: 04-17-11, 07:34 PM
  5. 2008 Islandia
    By machprodcomp in forum 4-Tec Sea-Doo Boats
    Last Post: 01-23-10, 07:17 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
