96 GTX SBT Replacement help 😐 - Seadoo Forums
15% off Hydro Turf 10% off WSM Parts Email Sales@PWCMuscle.com
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Page 1 of 3 123 LastLast
Results 1 to 25 of 75
  1. ☑ ORIGINAL POSTER #1
    Join Date
    Sep 2016
    Location
    Philadelphia
    Posts
    56
    Watercrafts
    96 seadoo gtx
    Thumbs Up
    Received: 0 Given: 0
    Default 96 GTX SBT Replacement help 😐
    96 Sea-Doo GTX 787... I bought this over the summer as a project, I bought an engine from SBT great people!!! I finally got around to putting the engine in, and I have one thing I can't figure out so far, there is a vacuum line coming from the rear of the ski that I can't figure out where the hell it goes??? Everything else seems to be hooked up and I can't find a spot for that??? I have a picture I will try to post with it!!! And help would be awesome Bc I wanted to attempt to fire it up tonight
    0 Not allowed!
  2. # ADS
  3. #2
    SeadooForum Pro soccerdad's Avatar
    Join Date
    Jan 2014
    Location
    Jamestown, NC
    Posts
    1,617
    Watercrafts
    '96 GSX- Lemonade '96 GTX- Shamu 2006 Bayliner 185, 3.0L
    Thumbs Up
    Received: 89 Given: 36
    Default
    If it ends near the battery box it is for a vent for acid batteries. It goes up towards the front of the ski and out a side vent. If you have an AGM battery, you do not need it.
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Join Date
    Sep 2016
    Location
    Philadelphia
    Posts
    56
    Watercrafts
    96 seadoo gtx
    Thumbs Up
    Default
    Is there one that connects to the top of the exhaust manifold? I have a hole there and was looking online and some show a line running there to a fitting which I don't have??? I was going to tap it and put a new one in unless it's not needed
    0 Not allowed!
  5. #4
    Experienced Rider ace422's Avatar
    Join Date
    Jun 2013
    Location
    miami
    Posts
    311
    Watercrafts
    96 seadoo gtx
    Thumbs Up
    Received: 13 Given: 4
    Default
    Does it run to the rear tow hook? If so thats the pisser line.
    0 Not allowed!
  6. #5
    Join Date
    Jan 2014
    Location
    Jamestown, NC
    Posts
    1,617
    Watercrafts
    Thumbs Up
    Default
    is it the one shown here? This is my 96 GTX.
    0 Not allowed!
  7. ☑ ORIGINAL POSTER #6
    Join Date
    Sep 2016
    Location
    Philadelphia
    Posts
    56
    Watercrafts
    96 seadoo gtx
    Thumbs Up
    Default
    Yes it runs to the tow hook!!!! And yes it's the one shown in the picture however it must have been broken off when I bought it Bc I don't remember it being there before I pulled the old engine... what should I do???? I was gonna drill and tap it... but what can I do??? Thanks!!!!
    0 Not allowed!
  8. #7
    Join Date
    Jan 2014
    Location
    Jamestown, NC
    Posts
    1,617
    Watercrafts
    Thumbs Up
    Default
    Well my ski is put away at the moment, but if that is the pisser line, then you can just plug it for a test. It will not hurt it running. But you should have one so you can see it is cooling and it may bleed air out. For sure you can start it that way. Is it an open hole? is it threaded?
    0 Not allowed!
  9. ☑ ORIGINAL POSTER #8
    Join Date
    Sep 2016
    Location
    Philadelphia
    Posts
    56
    Watercrafts
    96 seadoo gtx
    Thumbs Up
    Default
    Hard to tell I believe it is just an open hole, I was going to drill and tap it, my only fear being drilling too far or deep but I guess that is what has to be done... it doesn't look threaded it's hard to see the old fitting was probably brokenoff in there
    0 Not allowed!
  10. #9
    Join Date
    Jan 2014
    Location
    Jamestown, NC
    Posts
    1,617
    Watercrafts
    Thumbs Up
    Default
    Do you have ezouts?
    0 Not allowed!
  11. ☑ ORIGINAL POSTER #10
    Join Date
    Sep 2016
    Location
    Philadelphia
    Posts
    56
    Watercrafts
    96 seadoo gtx
    Thumbs Up
    Default
    Ok so got it started yay!!!! But... I pull the throttle and it bogs down??? What is my next step I was so excited for this and atleast it is starting!!!
    0 Not allowed!
  12. ☑ ORIGINAL POSTER #11
    Join Date
    Sep 2016
    Location
    Philadelphia
    Posts
    56
    Watercrafts
    96 seadoo gtx
    Thumbs Up
    Default
    Ok so it didn't start after a couple times I gave it a small shot of starting fluid it started and the rpms were way up I pulled the throttle and it bogged down... so I am guessing my carbs are out of adjustment? How and what do I do there?
    0 Not allowed!
  13. #12
    Join Date
    Jan 2014
    Location
    Jamestown, NC
    Posts
    1,617
    Watercrafts
    Thumbs Up
    Default
    Starting fluid is not good for it. Mix a little gas and injection oil, and spray it into the inlet of the carbs. It just needs to prime the system, as long as you did the carbs correctly. You hooked up the pulse line to the mag side carb, correct?
    0 Not allowed!
  14. ☑ ORIGINAL POSTER #13
    Join Date
    Sep 2016
    Location
    Philadelphia
    Posts
    56
    Watercrafts
    96 seadoo gtx
    Thumbs Up
    Default
    As far as I know they are hooked up correctly, I got them off of a donor ski so I think they might be out of adjustment I let it sit for a little and it fired up and idled high, came down a little but still really high
    0 Not allowed!
  15. ☑ ORIGINAL POSTER #14
    Join Date
    Sep 2016
    Location
    Philadelphia
    Posts
    56
    Watercrafts
    96 seadoo gtx
    Thumbs Up
    Default
    This is the first time I replaced a small engine I work on diesels, this small stuff confuses the sh*t out of me
    0 Not allowed!
  16. #15
    Join Date
    Jan 2014
    Location
    Jamestown, NC
    Posts
    1,617
    Watercrafts
    Thumbs Up
    Default
    It should idle at 3000 RPM. You can run it on the hose for a couple of minutes, but not longer or it will burn up the carbon seal on the drive shaft. And remember, start it, then water on, then water off, then shut it off. If you mess this up, start it up again immediately. Or you may have pumped water into the motor. Sounds like you are close though. Good job.
    0 Not allowed!
  17. ☑ ORIGINAL POSTER #16
    Join Date
    Sep 2016
    Location
    Philadelphia
    Posts
    56
    Watercrafts
    96 seadoo gtx
    Thumbs Up
    Default
    Wow 3000 rpm for idle I did not think it would be that high. Again all new to me.. I will test again tomorrow sometime if I get time, I also may have to adjust the carb for idle, if it stays high.. since the carbs were donors, they were shipped to me and might have got the screws moved or something but yes very close
    0 Not allowed!
  18. #17
    SeadooForum Pro manolocross's Avatar
    Join Date
    Sep 2010
    Location
    nyc
    Posts
    1,380
    Watercrafts
    1995 seadoo XP 720 1997 seadoo SPX 800
    Thumbs Up
    Received: 29 Given: 0
    Default
    You have to open the carbs and at least clean or rebuild them with genuine mikuni rebuild kits! Very important to do this step...., you got carbs from somewhere else and have no idea what's inside. They might be plugged up or dry and crusty. The carbs are the heart of these engines and if they are not right you will destroy your shiny new engine. Research on here on why and what needs to be done. At LEAST open and clean them!
    0 Not allowed!
  19. #18
    Join Date
    Jan 2014
    Location
    Jamestown, NC
    Posts
    1,617
    Watercrafts
    Thumbs Up
    Default
    +1 ^^^^^^^^ And the fuel lines need to be replaced as well if they are still gray. The fastest way to kill (about the only way to kill)* these motors is to run them lean. They need a perfect fuel system and the proper oil.
    *getting water in them and not getting it out quickly will also kill them...
    0 Not allowed!
  20. ☑ ORIGINAL POSTER #19
    Join Date
    Sep 2016
    Location
    Philadelphia
    Posts
    56
    Watercrafts
    96 seadoo gtx
    Thumbs Up
    Default
    I did clean the carbs as they were pretty damn clean when I got them, I took them apart and cleaned them,. Everything seemed good, I figured I will rebuild them after this season
    0 Not allowed!
  21. #20
    Join Date
    Jan 2014
    Location
    Jamestown, NC
    Posts
    1,617
    Watercrafts
    Thumbs Up
    Default
    Just for a note, it will idle at 3000 on the trailer, but only 1500 in the water with the water load on the pump.
    1 Not allowed!
  22. ☑ ORIGINAL POSTER #21
    Join Date
    Sep 2016
    Location
    Philadelphia
    Posts
    56
    Watercrafts
    96 seadoo gtx
    Thumbs Up
    Default
    Ok so I am back again and still need help.... I finally took the carbs out cleaned them out replaced all the fuel lines... re adjusted the carbs to factory specs checked the pop off settings... got
    Them back in and the Sea-Doo still just cranks????? I put some mixed fuel in the carbs it fired up and shit right off??! So I don't understand how I still have a fuel issue when everything is good? The only
    Thing I can think to do is drain the fuel tank and fill it with fresh new fuel?? Other than that I'm at a loss and getting so annoyed I don't even want to work on it
    0 Not allowed!
  23. #22
    Join Date
    Sep 2010
    Location
    nyc
    Posts
    1,380
    Watercrafts
    Thumbs Up
    Default
    Everything is not good....
    As long as we got that out the way first.
    Something wrong with fuel pump portion on carbs.Its not pulling gas into carbs. You have to check fuel lines also. Make sure they are in correct spots and fuel knob in ON position.
    0 Not allowed!
  24. #23
    Join Date
    Jan 2014
    Location
    Jamestown, NC
    Posts
    1,617
    Watercrafts
    Thumbs Up
    Default
    Like mano said, likely wrong plumbing. You can test it all by running a fuel line directly from the RES spud on the fuel baffle directly to the inlet on the carb. If that works, it is a fuel line issue. If it does not, you have something wrong in the carb, likely the fuel pump.
    0 Not allowed!
  25. ☑ ORIGINAL POSTER #24
    Join Date
    Sep 2016
    Location
    Philadelphia
    Posts
    56
    Watercrafts
    96 seadoo gtx
    Thumbs Up
    Default
    Ok so I figured it out, stupid stupid mistake, my fuel valve was turned off.... so now it fires right up... I just can't get my carbs dialed in correctly... here is the issue... it fires up on the trailer it is only idling at 1500.... when I know it should be around 3000... then I pull the throttle it bogs down and stalls... when I cleaned the carbs and put them back together I went with the factory settings and I know it will obviously vary.. but I was wondering which screw do I start with? And do I adjust both carbs to the same position?
    0 Not allowed!
  26. #25
    SeadooForum Hall of fame mikidymac's Avatar
    Join Date
    May 2012
    Location
    California
    Posts
    5,003
    Watercrafts
    2003 GTI 1996 XP 2001 XP 1996 HX 2x 1997 GSX
    Thumbs Up
    Received: 206 Given: 6
    Default
    Adjust the idle up to 3000 on the trailer. Use the idle adjustment screw not the mixture screws.
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. ECU Replacement
    By Captain RonJon in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 09-16-14, 02:43 PM
  2. VTS replacement
    By E9sling in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-10-12, 09:10 AM
  3. VTS Replacement
    By KyleB in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-03-12, 09:38 PM
  4. tow bar replacement
    By pomagiel in forum 4-Tec Sea-Doo PWC Forum
    Last Post: 05-06-11, 04:45 PM
  5. looking for a replacement...
    By cheekybobcat in forum Buy/Sell/Trade Sea-Doo Related
    Last Post: 05-17-09, 10:49 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
