Trailer vibration - Seadoo Forums
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 18 of 18
  1. ☑ ORIGINAL POSTER #1
    SeadooForum Pro Mekanix's Avatar
    Join Date
    May 2013
    Location
    Halifax, Nova Scotia, Canada
    Posts
    1,574
    Watercrafts
    96 GSX 800 2000 GS 717
    Thumbs Up
    Received: 38 Given: 21
    Default Trailer vibration
    I have an EZloader trailer withthe fat 8 inch tires.
    At highway speeds there is a strong vibration traveling through the hitch at 45 mph and again at 70.
    I've replaced, tires, hubs/bearings, bushings in the leaf springs.
    Even tried messing with tire pressure and and shifting the seadoo back to reduce the tongue weight.
    Not quite sure what is causing this but lookingback at one wheel i can see one fender shaking.
    Maybe axle alignment ?
    Stephen
    0 Not allowed!
  2. # ADS
  3. #2
    racerxxx's Avatar
    Join Date
    Aug 2012
    Location
    Chalfont, Pennsylvania
    Posts
    9,562
    Watercrafts
    89 SP, 91 XP,(2) 96 XP's, 99 Speedster Twin 800's , 95 HX, 95 XP800, 98 SPX
    Thumbs Up
    Received: 510 Given: 80
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Join Date
    May 2013
    Location
    Posts
    1,574
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by racerxxx View Post
    Single or double? Work box on the front?
    Single axle no work box.
    100lbs tongue weight.
    0 Not allowed!
  5. #4
    racerxxx's Avatar
    Join Date
    Aug 2012
    Location
    Posts
    9,562
    Watercrafts
    Thumbs Up
    Default
    I get it on my double at 45mph. Can't figure it out(I don't worry about it either), I just go faster and it goes away--not kidding. I think it has to do with the wind buffeting between the back of the vehicle and the work box. Everything else looks up to par too. And mine is a torsion axle not leafs. I have 7 trailers I tow at any given time, the only one does it and it's the only one with a work box.
    Best of luck!
    0 Not allowed!
  6. #5
    Junior Member
    Join Date
    Sep 2016
    Location
    Ohio
    Posts
    13
    Watercrafts
    12 John boat 96 Seado spi 96 Seado xp
    Thumbs Up
    Received: 0 Given: 0
    Default
    Maybe a bent rim?
    0 Not allowed!
  7. ☑ ORIGINAL POSTER #6
    Join Date
    May 2013
    Location
    Posts
    1,574
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by Briar View Post
    Maybe a bent rim?
    Replaced the rim/tire as a set. Along with hubs.
    Tried spinning the wheels up on jacks and they are pretty smooth.
    Soon thinking of just replacing the whole axle.
    0 Not allowed!
  8. #7
    Junior Member
    Join Date
    Sep 2016
    Location
    Ohio
    Posts
    13
    Watercrafts
    Thumbs Up
    Default
    They make balance powder we use it on semi truck tires. Not real expensive maybe ten bucks for a package of it you would probably only use about a quarter of it on each Tire or half a bag at the most. Tire would have to be partially broken down off rim to pour it in there that would be a quick way to make sure a tire or Rim isn't out of balance before you would replace a whole axle. Find a place that might sell larger semi truck tires or maybe Napa might even be able to get some for you
    0 Not allowed!
  9. #8
    racerxxx's Avatar
    Join Date
    Aug 2012
    Location
    Posts
    9,562
    Watercrafts
    Thumbs Up
    Default
    Plastic bb's for air soft guns, a guy I work with balances his tires on his jeep that way. No problems and yes, he drives on highways.
    0 Not allowed!
  10. #9
    Junior Member
    Join Date
    Sep 2016
    Location
    Ohio
    Posts
    13
    Watercrafts
    Thumbs Up
    Default
    Same Theory those would work also
    0 Not allowed!
  11. ☑ ORIGINAL POSTER #10
    Join Date
    May 2013
    Location
    Posts
    1,574
    Watercrafts
    Thumbs Up
    Default
    Good ideas.
    What would a trailer with a misaligned axle feel like or what would it do while moving.
    I'm thinking it would crab sideways and jump around but its not moving sideways at all.
    0 Not allowed!
  12. #11
    Junior Member
    Join Date
    Sep 2016
    Location
    Ohio
    Posts
    13
    Watercrafts
    Thumbs Up
    Default
    Probably notice iregular regular tire wear one side of the tire
    0 Not allowed!
  13. ☑ ORIGINAL POSTER #12
    Join Date
    May 2013
    Location
    Posts
    1,574
    Watercrafts
    Thumbs Up
    Default
    Hmm. New tires, too soon for wear paterns. Old tires had the inner and outer edges worn down on both sides. And the center raised higher above the rest of the tread.
    0 Not allowed!
  14. #13
    Junior Member
    Join Date
    Sep 2016
    Location
    Ohio
    Posts
    13
    Watercrafts
    Thumbs Up
    Default
    That sounds sort of like low air pressure.
    0 Not allowed!
  15. #14
    Member k_24's Avatar
    Join Date
    Jun 2012
    Location
    toronto
    Posts
    79
    Watercrafts
    00 seadoo xp 951cc
    Thumbs Up
    Received: 0 Given: 12
    Default
    Quote Originally Posted by Mekanix View Post
    Inner and outer worn just means it wasnt inflated properly for a while
    0 Not allowed!
  16. #15
    Join Date
    Jun 2012
    Location
    toronto
    Posts
    79
    Watercrafts
    00 seadoo xp 951cc
    Thumbs Up
    Default
    Check to see if the spindle isnt bent on the axle .
    Raise it up and check that the wheel has no play usualy tighten the nut all the way and reverse 1/4 turn
    Also if u have a wheel hub/bearing buddy make sure its not all dented up
    One hillbilly way to check if axle is aligned is to mark center of axle on each side and then to check with a measuring tape left and right side from the taillight to center of the axle on each side
    0 Not allowed!
  17. ☑ ORIGINAL POSTER #16
    Join Date
    May 2013
    Location
    Posts
    1,574
    Watercrafts
    Thumbs Up
    Default
    Found the left side to be toed out slightly and the right side to be square...
    Think I might rotate the axle to turn that toe into camber and see if I can get it to run straighter and see if that fixes it.
    What should be the tire pressure for this trailer?
    0 Not allowed!
  18. #17
    SeadooForum Pro suke's Avatar
    Join Date
    Sep 2012
    Location
    Holly Springs, NC
    Posts
    1,578
    Watercrafts
    96 XP, 96 Wave Venture 700
    Thumbs Up
    Received: 34 Given: 10
    Default
    My single trailer does the same thing. I swapped wheels/tires with my double that play super smooth. Thought it was just the weight. I did notice one side is a half inch further on the axle within the fender. I towed it with the new wheels the other day and all is gone..... So far. Getting ready to drive it 2 hours on the highway here Sat. Should know if I need to adjust out that half inch or not.
    0 Not allowed!
  19. #18
    Join Date
    Jun 2012
    Location
    toronto
    Posts
    79
    Watercrafts
    00 seadoo xp 951cc
    Thumbs Up
    Default
    Tire pressure is written on the tire max 750 lb at 45 psi for example deflate 5psi below indicated to get a softer ride
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. 2000 GTX, XP, double trailer, single trailer, engine all for sale.
    By SabrToothSqrl in forum Buy/Sell/Trade Sea-Doo Related
    Last Post: 01-11-15, 03:02 PM
  2. Replies: 0
    Last Post: 09-27-14, 11:42 AM
  3. Replies: 0
    Last Post: 03-11-14, 11:28 PM
  4. Trailer TONGUE weight for 2006 speedster 200 single axle trailer?
    By darren44_4 in forum 4-Tec Sea-Doo Boats
    Last Post: 09-03-13, 12:05 PM
  5. 97 GTi, small vibration, big vibration, quit, no spark
    By luv2pla in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 04-13-11, 10:27 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
