951 runaway throttle - Seadoo Forums
15% off Hydro Turf 10% off WSM Parts Email Sales@PWCMuscle.com
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 6 of 6
  1. ☑ ORIGINAL POSTER #1
    Member Jaxtoce1's Avatar
    Join Date
    Jul 2014
    Location
    Billerica MA
    Posts
    68
    Watercrafts
    24ft Fourwinns deck boat 15.5 ft sea nymph 25hp (All are run in fresh water)
    Thumbs Up
    Received: 1 Given: 0
    Default 951 runaway throttle
    I have a 2000 seadoo GTX millennium edition..
    Story goes, I was told by PO that all gray lines were replaced by dealership.. I found a few extra gray lines and instead of just looking up what they were (to find out that there vent lines) I just went right after them... ended up breaking off a nipple coming off the carb and had to buy a new piece.
    Now to replace this piece you have to remove the little holder for the throttle cable, that cable then goes around a wheel type thing..
    Before I did this the ski ran fine no problems, now everytime I start it, it immediately goes banging off the rev limiter... I'll include some pictures, I was suppose to be on the water last week, so any help is much appreciated
    Thanks guys
    0 Not allowed!
  2. # ADS
  3. #2
    Jasonv's Avatar
    Join Date
    Sep 2015
    Location
    Buckingham virginia
    Posts
    309
    Watercrafts
    01 seadoo xpl 5 97 seadoo spx 98 seadoo spx 97 seadoo XP 3 96 seadoo XP 02 seadoo gti
    Thumbs Up
    Received: 8 Given: 3
    Default
    I recently just went through this. First off does the ski shut off when you hit the button or pull the lanyard. If so your throdlle cable might be to tight.
    0 Not allowed!
  4. #3
    Join Date
    Jan 2011
    Location
    Tampa
    Posts
    209
    Thumbs Up
    Received: 19 Given: 0
    Default
    Classic too tight throttle cable syndrome. Check for slack in the cable, there should be a little slack.
    0 Not allowed!
  5. ☑ ORIGINAL POSTER #4
    Join Date
    Jul 2014
    Location
    Billerica MA
    Posts
    68
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by Sea Dood View Post
    Idk about that but I do know there is 2 holes in the circle thing it connects to. Why is that there? Which hole should it be on? I did tighten the throttle cable at the bracket where it attached because it was wiggling and loose a little but I didn't think that effected the actual throttle I just thought that adjusted how tight the actual cable was to the bracket.. how do I go about fixing this? Basically just loosen it back up again and see if that fixes it? Maybe it was suppose to be like that?
    Thanks again for the quick help guys, I'm used to working on 787's so this 951 is a new beast to me
    0 Not allowed!
  6. #5
    SeadooForum Hall of fame mikidymac's Avatar
    Join Date
    May 2012
    Location
    California
    Posts
    4,120
    Watercrafts
    2003 GTI 1996 XP 2001 XP 1996 HX 2x 1997 GSX
    Thumbs Up
    Received: 182 Given: 4
    Default
    The bracket should definitely be tight. You just need to adjust the cable. Make sure you hear the throttle butterflies snap close when you release the throttle. There should also be a couple millimeters of play in the throttle lever.
    0 Not allowed!
  7. ☑ ORIGINAL POSTER #6
    Join Date
    Jul 2014
    Location
    Billerica MA
    Posts
    68
    Watercrafts
    Thumbs Up
    Default
    All set now looks like the PO had it so that the wire actually ran through both holes.... craziest thing I've ever seen but I'm all good now, thanks for the help though guys !!
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. runaway engine
    By bammajamma in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 10-05-13, 02:09 PM
  2. After carb rebuild runaway throttle
    By Hobiedog in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 06-05-12, 09:48 AM
  3. rebuild now runaway
    By fordarmyof1 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 01-20-12, 08:19 PM
  4. starter runaway
    By slvr bulit in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 04-27-09, 07:56 PM
  5. '96 GTI runaway throttle
    By Bradley in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 02-08-09, 09:40 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
