My 07 rxt giving a single beep as accelerating - Seadoo Forums
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 14 of 14
  1. ☑ ORIGINAL POSTER #1
    Senior Member Rrm1387's Avatar
    Join Date
    Oct 2009
    Location
    long island
    Posts
    196
    Watercrafts
    07 Rxt 215 s/c oh yea!!! 03 gtx supercharged 4 stroke 03 edgewater 265cc
    Thumbs Up
    Received: 2 Given: 0
    Default My 07 rxt giving a single beep as accelerating
    My first time out this year. Put the key in got two beeps and the dash said 12v low. As i accerlerated i get a beep . It runs fine and sounds good. I replaced the battery ,changed the plugs and oil. I am not getting any other lights or warning just an occasional beep. I checked the oil and it was at the top of the oil range so i removed around a half a quart. I put the battery back on charge and it seems low. Would any of these things cause my beep.
    0 Not allowed!
  2. # ADS
  3. #2
    Junior Member
    Join Date
    Apr 2017
    Location
    AU
    Posts
    6
    Thumbs Up
    Received: 0 Given: 0
    Default
    You pretty much answered your own question. The charge system isnt working. Check volts while running. I just replaced my regulator about a month ago for the same issue. You want 13.5+ at idle
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Join Date
    Oct 2009
    Location
    long island
    Posts
    196
    Watercrafts
    Thumbs Up
    Default
    Just wanted to update my finding. I charged my battery and was showing around 12.89 volts. I started the ski and the volts dropped to around 12.45. So I guess the regulator isn't working?
    0 Not allowed!
  5. #4
    Junior Member
    Join Date
    Apr 2017
    Location
    AU
    Posts
    6
    Thumbs Up
    Default
    You could assume so.
    The 3 yellow wires going to the reg/rec.
    Put yor voltmeter on AC and test for voltage.
    From memory it should be about 60v AC at about 3000rpm.
    If its around that 60v mark. then replace regulator
    0 Not allowed!
  6. ☑ ORIGINAL POSTER #5
    Join Date
    Oct 2009
    Location
    long island
    Posts
    196
    Watercrafts
    Thumbs Up
    Default
    of course my problems are never that easy. I put in a new rectifier and there was no change. As I increased the rpms there was no change in the meter.
    0 Not allowed!
  7. #6
    Junior Member
    Join Date
    Apr 2017
    Location
    AU
    Posts
    6
    Thumbs Up
    Default
    Did you test for ac voltage on the 3 yellow wires? Probably a ****ed stator
    0 Not allowed!
  8. ☑ ORIGINAL POSTER #7
    Join Date
    Oct 2009
    Location
    long island
    Posts
    196
    Watercrafts
    Thumbs Up
    Default
    I will test the 3 yellow wires today. I read a post that suggests I should test it where it plugs in by the oil filter and also where it plugs into the rectifier? For the stator I basically have to remove the back half of the ski? What kind of volts am I looking for?
    0 Not allowed!
  9. #8
    Junior Member
    Join Date
    Apr 2017
    Location
    AU
    Posts
    6
    Thumbs Up
    Default
    As i said above. Something like 60v AC at 3000rpm.
    And like 20v AC at idle.
    Just test it where ever.
    I just used the multimeter probes to stab holes in the wires. Then taped up
    0 Not allowed!
  10. ☑ ORIGINAL POSTER #9
    Join Date
    Oct 2009
    Location
    long island
    Posts
    196
    Watercrafts
    Thumbs Up
    Default
    I just tested it at the back had around 22 or 23 at idle. I also tested it by the rectifier. The diode test of the old rectifier had nothing. I tested the new rectifier and it showed numbers on all points. there is relay at the fuse block tyco relay part #VJ28-95F74-S01. Does that effect the charging system.
    0 Not allowed!
  11. ☑ ORIGINAL POSTER #10
    Join Date
    Oct 2009
    Location
    long island
    Posts
    196
    Watercrafts
    Thumbs Up
    Default
    Still not charging i purchased a seadoo rectifier thinking after market no good . The dcv volt meter does not move dropes to 12.3 and stays there . Any ideas
    0 Not allowed!
  12. #11
    Junior Member
    Join Date
    Jun 2017
    Location
    NY
    Posts
    19
    Watercrafts
    SeaDoo Challenger 180-2008
    Thumbs Up
    Default
    Rrm1387..What was the issue and How did you ended up solving it?
    0 Not allowed!
  13. ☑ ORIGINAL POSTER #12
    Join Date
    Oct 2009
    Location
    long island
    Posts
    196
    Watercrafts
    Thumbs Up
    Default
    I could not figure out where the d/c current was going. So I ended up bringing it to a mechanic I use. It turned out there was resistance in the fuse block .He ran two new wires to the fuse block and that fixed it . I narrowed it down that a/c current was making it to the rectifier but not to the fuse block as d/c.
    0 Not allowed!
  14. #13
    Junior Member
    Join Date
    Jun 2017
    Location
    NY
    Posts
    19
    Watercrafts
    Thumbs Up
    Default
    RMR1387,
    I'm having the same exact issue..I just bought rectifier and install it..but same thing. Where is the FUSE BLOCK? Do you have any picture? THANK YOU VERY MUCH!!
    0 Not allowed!
  15. ☑ ORIGINAL POSTER #14
    Join Date
    Oct 2009
    Location
    long island
    Posts
    196
    Watercrafts
    Thumbs Up
    Default
    He added two hot wires to the battery and charging relay because he said there was resistance . pictured is a black tube running to the bottom of the fuse block
    Attached Images Attached Images
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Single load (random) beep
    By Carboncow in forum 4-Tec Sea-Doo Boats
    Last Post: 08-28-16, 11:53 PM
  2. 2004 RXP long beep when accelerating
    By Kentucky mark in forum 4-Tec Sea-Doo PWC Forum
    Last Post: 07-28-13, 10:17 PM
  3. Single beep while cruising but nothing on the gauges?
    By fearthisinc in forum 4-Tec Sea-Doo Boats
    Last Post: 07-09-13, 03:38 PM
  4. Single Beep while riding
    By HooverAl in forum 4-Tec Sea-Doo PWC Forum
    Last Post: 06-06-13, 02:36 PM
  5. 2001 GTS Dies as accelerating then 1 beep
    By rshaker2 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 08-26-11, 02:26 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
