Seadoo DI (Direct Injection) Fuel Pump Replacement Guide - Page 4 - Seadoo Forums
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Page 4 of 4 FirstFirst ... 234
Results 76 to 98 of 98
  1. #76
    Junior Member
    Join Date
    Jul 2014
    Location
    Michigan
    Posts
    4
    Watercrafts
    Seadoo XP DI
    Thumbs Up
    Received: 0 Given: 0
    Default
    DooWacka, wanted to let you know that thanks to your help I was able to isolate the HighFlow pump I received and bench test. It was in fact not developing sufficient pressure. I contacted Axiom Performance (HighFlow) and was immediately shipped a replacement pump. I installed it and it works perfect with a very manageable current draw and the required pressure. The customer service at Axiom Performance is outstanding and they seem intent on continued improvement to offer the best pump possible for this difficult DI application.
    0 Not allowed!
  2. # ADS
  3. #77
    Join Date
    Jul 2014
    Location
    TN
    Posts
    46
    Watercrafts
    2002 SeaDoo GTX DI
    Thumbs Up
    Received: 1 Given: 3
    Default
    I just completed this, and boy it was easy! Thanks for such a great write-up. The pump from Highflow arrived very quickly to east TN.
    My symptoms were random shutdown, instant, no bogging, no codes, fuel pressure tested fine at the shop. I was told everything from electrical, injectors, bad gas, and a lot of other guesses which would have been costly to guess at and part swap. Unfortunately my compression was around 120 PSI at 244 hours, so I went ahead and had SES rebuild the engine (which turned out great). I replaced the fuel pump, a Baldwin fuel filter BF1049, stainless fuel injection hose clamps, and a Tee with needle valve for future testing and a 160PSI gauge installed in the glove box. I really like being able to open the glove box and seeing the pressure dead on 107PSI!
    Anyway, changing the large fuel filter and installing the pressure gauge was $50. I would recommend that to anyone having similar issues. Thanks again for the great write-up.
    *edit*
    I forgot to add, for thread sealant, rector seal 5 works great. It is rated for fuel (amongst other things), multiple types of metal, and up to 10,000psi with gasoline. You can also pick it up at any hardware store, and it's cheap.
    0 Not allowed!
  4. #78
    Experienced Rider donkey's Avatar
    Join Date
    May 2012
    Location
    lake havasu/ yucca valley
    Posts
    652
    Watercrafts
    1 98 seadoo xp 1 96 xp's 2 95xp's,, 97spx 77 rallye
    Thumbs Up
    Received: 21 Given: 91
    Default
    thanx for the writeup,im just about to tackle the neighbors di pump issue!
    0 Not allowed!
  5. #79
    Junior Member
    Join Date
    Jun 2015
    Location
    Canada
    Posts
    2
    Watercrafts
    2003 LRV DI Seadoo PWC
    Thumbs Up
    Default
    Thanks for the instructions, they came in very handy.
    I ordered my replacement pump and when I took my original apart, I found I had a broken seal which may be the cause of my issues. Any idea on where I could get a seal?
    Any help appreciated as I have this thing ripped apart in my back yard!
    0 Not allowed!
  6. ☑ ORIGINAL POSTER #80
    Senior Member DooWacka's Avatar
    Join Date
    Jul 2010
    Location
    Littleton, CO
    Posts
    241
    Watercrafts
    currently four 2001 GTX DI
    Thumbs Up
    Received: 20 Given: 6
    Default
    I don't know of anyone that knows where they can be purchased. My local BRP dealership says that they don't have a source either, and if the "sliding seal" goes out, they have to replace the whole fuel pump module. You can see if someone has a non-functional module, to scavenge that part. Or you can do what I have done and see if you get lucky when calling the dealerships about used modules. The dealerships just throw the old modules away when replacing them. I have asked for and been given the old modules for parts or rebuilding.
    As a last resort you can abandon the "sliding seal" feature and clamp a hose directly between the pump and the rigid black tube, as others have done.
    0 Not allowed!
  7. #81
    Junior Member
    Join Date
    Jun 2015
    Location
    Canada
    Posts
    2
    Watercrafts
    Thumbs Up
    Default
    Thanks for your reply DooWacka and advice, I really appreciate you taking the time!
    As a follow up to yesterday, since I had everything apart, I ended up using part of a fuel hose and sliding it into the silver shaft. It is a very tight fit but seems to work. I installed everything and the Seadoo started. I did some pressure tests and things seem to be working!!!! I attached a pic in case it might help others. I am planning to use the Seadoo in 2 weeks so I will let everyone know if it didn't work!
    Thanks again for the advice!
    0 Not allowed!
  8. #82
    Junior Member
    Join Date
    Jun 2015
    Location
    Virginia
    Posts
    7
    Watercrafts
    06 Sportster 97 XP 96 XPS
    Thumbs Up
    Default
    DooWacka,
    Thanks for the thread. A google search led me to it so I went ahead and joined.
    It sounds like it'll work for my 06 Sportster but thought I'd ask the expert. Yes?
    I'm blowing the 10A fuse for the pump and the shop said that the CEL is because the fuel pump is shorted. When I put a 15A fuse in, I can get the starter to crank but it won't start. When I pull the fuel line, there's no fuel being pumped. There's no way I'm paying $780 for a new fuel pump so your fix sounds like my best chance of getting back out on the water this year. By the way, when I looked up the P/N for my fuel pump it's the same one that's used in the Can Am (go figger).
    My original intention was to purchase an in line fuel pump and just fabricate my own port from the bottom of the tank, cut the leads to the fuel pump and connect them to the new one but leave the old one in place. In reading the thread though, it sounds like there is not an active fuel pressure regulator in the system. The fuel pump just drains fuel from the high pressure line back in to the tank to release pressure back down to 107 psi. Is that true? I bought a 140 psi pump that hasn't arrived yet for $50 off of ebay. Will that pressure damage the system?
    Thanks for any help you can give.
    t4b
    0 Not allowed!
  9. #83
    SeadooForum Pro lamajama's Avatar
    Join Date
    Jan 2010
    Location
    Vancouver BC
    Posts
    1,126
    Watercrafts
    04 GTX SC, 02 GTX 4 tec, 08 GTX SC 215
    Thumbs Up
    Received: 25 Given: 21
    0 Not allowed!
  10. #84
    Junior Member
    Join Date
    Jun 2015
    Location
    Virginia
    Posts
    7
    Watercrafts
    Thumbs Up
    Default
    Thanks lamajama. I'll let you know but I want to wait to see what DooWacka has to say first.
    0 Not allowed!
  11. ☑ ORIGINAL POSTER #85
    Join Date
    Jul 2010
    Location
    Littleton, CO
    Posts
    241
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by tom4bren View Post
    DooWacka,
    t4b
    Looking at the very first post in this thread, I have a table showing all the DI PWC that I thought BRP made, I don't see an '06 Sportster, just '04 and '05. But if it is a DI then you most likely need the high pressure pump.
    When these OEM pumps get older you will often have an increase in amps drawn until the fuse blows.
    Don't mess with an external pump, just rebuild the fuel pump module as is shown in the guide, and as many have done before.
    There is a fuel pressure regulator in the Fuel/Air Rail, that just allows any extra fuel to return to the tank. Your new pump may be capable of 140 psi, but the regulator will never allow that pressure to build. I have tested the OE pump to over 160 psi. The regulator allows the rail to stay at the 107 psi required.
    Is the new 140 psi pump an in-tank replacement? If so, could you give a link so people can see?
    The problem is not just finding a pump to give the 107 psi pressure, but doing it with a reasonable current draw of under 9 amps. The OE pump only draws about 4 to 5 amps. If your pump draws to much, not only the battery doesn't charge but the MPEM doesn't like it and gets flakey. There are also other problems associated with to high of current draw. There are several automotive pumps that can give the pressure required but draw 12+ amps to do so. The manufacturers of those pumps don't care about current since there is plenty available in the vehicle. The BRP 951 Magneto puts out about 220 watts, so that is about 18 amps max. That is all you have to run everything including charging the battery.
    There are plenty of in-tank fuel pumps on eBay and elsewhere that advertise working in a DI, so I hope you haven't selected an automotive external pump that would probably draw 16 amps.
    0 Not allowed!
  12. #86
    Junior Member
    Join Date
    Jun 2015
    Location
    Virginia
    Posts
    7
    Watercrafts
    Thumbs Up
    Default
    DooWacka,
    Thanks for the response. When the pump I ordered arrives, I'll do a quick test for power draw & let you know (no need to post source till I find out if it'll work).
    I'm starting to think that I'll prolly backpedal and go with your solution even though I've already bought the other pump ... just so I'll have the lifetime warrantee on the new pump. I think I want to run a few more tests on the boat though before I purchase anything else.
    lamajama,
    If you get an offer on your pump go for it. I'll contact you if interested in a few weeks to see if it's still available.
    Tom
    0 Not allowed!
  13. #87
    Join Date
    Jan 2010
    Location
    Vancouver BC
    Posts
    1,126
    Watercrafts
    Thumbs Up
    Default
    Sure Tom, thanks.
    0 Not allowed!
  14. #88
    Junior Member
    Join Date
    Jun 2015
    Location
    Virginia
    Posts
    7
    Watercrafts
    Thumbs Up
    Default
    The new pump arrived on Friday & I installed it on Saturday. I was elated when it immediately fired up. I shut it down so I could attach a hose to run it longer. Now it won't re-start. Is there a chance that there is air in the line up to the fuel rail that needs to be bled out? I ran the battery down trying to re-start it but haven't tried again since the battery is now charged.
    0 Not allowed!
  15. ☑ ORIGINAL POSTER #89
    Join Date
    Jul 2010
    Location
    Littleton, CO
    Posts
    241
    Watercrafts
    Thumbs Up
    Default
    I hope you know to have the motor running before turning on the hose. The exhaust pressure keeps the tuned pipe cooling water out of the combustion chamber.
    There would be no air in the fuel circuit to the rail.
    If you got water in the motor, try to kick it out by running "drowned mode", holding the throttle at wide open then cranking. It won't start, but tries to push out any water in the cylinders and case. If you have any water in there, don't leave it very long since it will start rusting any surface not coated well with oil.
    If you didn't have a water mistake, then you probably need to check the fuel pressure.
    0 Not allowed!
  16. #90
    Junior Member
    Join Date
    Jun 2015
    Location
    Virginia
    Posts
    7
    Watercrafts
    Thumbs Up
    Default
    Yes, engine start first ... then turn on water. It's just a real BEEEOTCH to attach the hose so I don't like to have the engine running whilst trying to hook it up.
    I'll keep playing with it & let you know when I have success.
    0 Not allowed!
  17. #91
    Join Date
    Jan 2010
    Location
    Vancouver BC
    Posts
    1,126
    Watercrafts
    Thumbs Up
    Default
    A word to the wise too. Don't leave the seadoo at all while it's on the hose and running. I knew of a guy who went into his house for a "few minutes"
    and the seadoo had stalled while he was away from it.....you know the rest of the story....
    0 Not allowed!
  18. #92
    Junior Member
    Join Date
    Jun 2015
    Location
    Virginia
    Posts
    7
    Watercrafts
    Thumbs Up
    Default
    Duly noted. I'm easily distracted so I won't leave it running unattended.
    BTW, I don't think your fuel pump assy would have worked for me. The 06 Sportster uses a different pump than what started this whole thread (they did have one at the same place though. Mine uses the same one that Bombardier is still putting in the Can Am. Thanks for the offer though.
    0 Not allowed!
  19. #93
    Join Date
    Jan 2010
    Location
    Vancouver BC
    Posts
    1,126
    Watercrafts
    Thumbs Up
    Default
    No problem! Good luck sorting it out. I do miss the DI's fuel consumption. Barely a trickle compared to the 4 stroke!
    0 Not allowed!
  20. #94
    Junior Member mrbill3's Avatar
    Join Date
    Feb 2009
    Location
    Fair oaks
    Posts
    6
    Watercrafts
    Pair of 02 GTX DI's
    Thumbs Up
    Default
    great instructions! just got done doing it twice.
    The best part about have two 2002 GTX DI's is all the extra trouble shooting you will do just cause you have the wrong key in it...
    Thanks again.
    0 Not allowed!
  21. #95
    Join Date
    Mar 2010
    Location
    toronto
    Posts
    35
    Watercrafts
    2002 rxdi
    Thumbs Up
    Default
    I think I know why my seadoo mechanic says my fuel pump is incorrect now... Didn't realize there would be so much fab work and macguyvering to get it to work... Kinda glad too tough since I know I can do this myself when I pick up the ski this weekend
    Chris
    0 Not allowed!
  22. #96
    Junior Member
    Join Date
    Jul 2016
    Location
    Phoenix
    Posts
    1
    Watercrafts
    2001 Seadoo GTX DI
    Thumbs Up
    Default
    Hey Doowacka,
    With another season in progress, any update on the fuel pump reliability? Looks like the DI fuel pump price has come down ($79.99 from high flow). I'm experiencing intermittent high rpm issues, and am getting ready to take it to an independent repair shop. Symptoms seem to indicate a fuel pump issue; once it's confirmed by a fuel pressure check, I'm looking at the high flow product.
    0 Not allowed!
  23. #97
    Junior Member
    Join Date
    Aug 2017
    Location
    OHIO
    Posts
    2
    Watercrafts
    2002 Sea Doo GTX DI
    Thumbs Up
    Default
    Hi all, First time posting but I've done a LOT of reading here. I recently worked on a neighbors 2002 GTX DI that would start and run for about 2 seconds then stall. I found a problem and solution for the low fuel pressure issue that I have not seen anyone come across that I could find anyway. I could get about 80 PSI out of the pump no matter how I checked it, inline, dead heading it, in the tank, out of the tank. I replaced it with a High Flow Fuel HFP 342 DI with the same exact results....80 PSI. I thought maybe I received a faulty pump but thought it odd that I got the same pressure. Maybe I had a bad seal where the pump mates up to the housing with the black tube that slides into the pump. I put everything back together and raised the pump a few inches out of the tank so I could see if it was leaking back into the tank. I cranked it over and fuel sprayed from the top of the pump housing, not from the seal where I thought, back into the tank. The steel piece where the fuel pressure line and the return line hook up was very rusty and I assumed must have rusted through internally and let the fuel dump right back in the tank instead of building pressure. I took it apart and what I found was rust had built up so much that it pushed the 2 piece housing apart which had unseated 2 O-rings that keep the high pressure fuel apart from the return fuel. I cleaned the rust off with a hammer, file and emery cloth. The O-rings and their sealing surface were still in great shape so I put it all back together and waala 107 PSI. It cranked a couple times and started right up and runs fine on the hose. I apologize for the long post but did so in hopes of helping someone else as much as all of you have helped me. Thanks, Dan
    Attached Images Attached Images
    0 Not allowed!
  24. #98
    Junior Member
    Join Date
    Aug 2017
    Location
    OHIO
    Posts
    2
    Watercrafts
    2002 Sea Doo GTX DI
    Thumbs Up
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. 2000 Seadoo GTX Rotax Direct Injection engine in parts
    By superchip2000 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 03-05-13, 01:16 PM
  2. Replies: 0
    Last Post: 09-24-12, 04:30 PM
  3. 1995 SeaDoo Speedster Direct injection to premix Question
    By Jimimad in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 07-30-10, 10:44 AM
  4. direct injection
    By Chauncey in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-05-09, 09:44 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
