azsxr
I’m having a runaway issue on my fresh rebuild. I pressure tested it before I installed it
and it passed. I set the idle at 3000and it will stay the same but when I give it some gas it rev’s up
and takes a few sec’s to go back. When I rev it a bit more the idle will only go back to 3500
Rev it again and it runs away.
I know it a leak but I’ve check it wd 40 and couldn’t find it I even tried some starting fluid and nothing. I sprayed around the rear crank seal,carb base gaskets , cylinders to case ,manifold and cases.I pulled the carbs and manifold
everything was good but it does the same thing.
I was trying not to pull the engine but what else could it be?
