Doctors Orders
Hello all- I have a question that I'm hoping someone may have an answer for....
I have a 2005 Sea Doo GTX Wake... It has developed a stalling problem- BUT only once the engine warms up... Cold start is just fine and she runs normally at first ... After running hard for a good 10-15 minutes she runs a little sluggish and will stall as soon as I let off of the throttle... Then she won't start unless I give her some throttle while pressing start... She will run "OK" until I let off the throttle- then immediate stall... Once the engine cools down- back to starting and idling just fine.
Important note- the ENGINE TEMP on the gauge cluster reads 78' ALL THE TIME- cold start OR after running hard. That's impossible since the LAKE temp is 82' ... So I'm thinking maybe a failed engine coolant temp. sensor? Maybe that would affect the lean/rich mixture once engine has heated up ? There are no engine codes or check engine- but maybe staying at 78' wouldn't trigger that?
Ideas? I have already changed spark plugs and coils, and treated the fuel... Dealer reset the computer for me.
Thanks everyone for your help.
Tony
Tony
