Mercury 240 EFI engine shuts off at high speed - HELP - Seadoo Forums
Visit PWCMuscle.com
for 15% off all Hydro Turf - CODE: HYDRO15
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 25 of 25
  1. ☑ ORIGINAL POSTER #1
    Junior Member
    Join Date
    Sep 2008
    Location
    Montreal, Quebec, Canada
    Posts
    1
    Watercrafts
    2002 Speedster 240 EFI
    Thumbs Up
    Received: 0 Given: 0
    Default Mercury 240 EFI engine shuts off at high speed - HELP
    I have a 2002 speedster with the Mercury 240 EFI 6 cylinder engine. When I go on full throttle, the engine just shuts off. No sputtring or anything, just quietly shuts off. I am able to start the engine back immediately, but this problem is getting to be too frequent. If I go at less than full throttle, it does not happen. I have cleaned the plugs, and it did not help, the engine still shuts off at higher speeds. Someone please help. Thanks in advance..
    0 Not allowed!
  2. # ADS
  3. #2
    Experienced Rider
    Join Date
    Jul 2008
    Location
    Arkansas
    Posts
    621
    Watercrafts
    Old boat, got motor running, 1972. With 1971 4 cylinder merc on back. Runs good now! 1998 Sea Doo G
    Thumbs Up
    Default
    1st off, I simply do not know.
    But, I will levy my guesses.
    I think the RPM limiter is malfunctioning. I think that as soon as it hits too high of an rpm, that would allow the rev limiter to kick in, it kills the motor, and then when you hit the starter, to restart, it has been through a reset, and then all is well. Until you get the revs up again.
    I am not for sure on this, but you might remove the "key" DESS system, then run it through diagnostics, and a reset, and solve it.
    I don't know what I am talking about, but my guess work is often better than some dealers working on it, at 100 buks an hr!
    Nate
    PS, can this feature be added to a mother in law?
    He heheh
    I love all things mechanical.
    Nate
    0 Not allowed!
  4. #3
    Junior Member
    Join Date
    Feb 2008
    Location
    RI
    Posts
    11
    Watercrafts
    2001 Challenger 2000 (Mercury M2 (240EFI))
    Thumbs Up
    Default
    have you read the M2 service manual? there are multiple things that can cause that. there is a whole section troubleshooting fuel and sensors. it could be your TPS, MAP sensor, wide open adjustment on the throttle itself and so on... does it stall at a certian RPM or a certian % throttle while accelerating to full throttle?
    0 Not allowed!
  5. #4
    seadoosnipe's Avatar
    Join Date
    Sep 2007
    Location
    Deep South
    Posts
    9,851
    Watercrafts
    1997 Challenger, 1997 GTX , 1991 SP and a shop with 2 spare 787cc's and a bunch of parts laying arou
    Thumbs Up
    Received: 75 Given: 0
    Default M-2..........
    The EFI M-2 Mercury is a totally computerized engine. It takes signals from one or more sensors and makes adjustments to your timing, fuel system and other engine management components.
    YOur problem seems electrical though..........
    Looking for tips and advice, researched articles on carbs, spark plugs and general maintenance can be found at Snipes Korner. You can also follow me on "Twitter".
    Quality parts at low prices, visit Seadoowarehouse right here in our own forum. Please PM me if you are having a problem finding what you need!
    Is your jet ski fast? Do you want your XP or RXP to stand out? I know a place that has what you need to make it faster. Make your jetsksi a muscle craft, not just the ordinary, standard stock ski.
    Seen my GTX?... Those awesome graphics can be purchased from JetSki Detailing. Tell them Seadooforum sent you.
    Ever wonder what the inside of your 787cc engine looks like. Want to identify the parts, check out my thread on the 787. I'm sure there is something for everyone who want to learn about the internal parts.
    0 Not allowed!
  6. #5
    Junior Member
    Join Date
    Feb 2009
    Location
    Texas
    Posts
    17
    Watercrafts
    2002 Seadoo Utopia 205 with Bennett Hydraulic Trim Tabs 1997 Seadoo GTX 1995 Seadoo GTS
    Thumbs Up
    Default Help... Seadoo Utopia Lunging/Cutting Out - water in fuel? or computer/sensor issue?
    Hi Kapeed, did you ever figure out the issue here?
    My 2002 Seadoo Utopia 205 with Merc 240EFI is having similar problems. I'm wondering if there's water in the fuel, or a computer/sensor issue, but not sure.
    When just above idle, the engine suddenly cuts out, then comes back, then cuts out. Sometimes it cuts out completely and I have to restart it. When it comes back, it lunges forward obviously, then cuts back again.
    As I accelerate further I seem to be able to eventually get it past the lunging and then it will run perfect on plane mostly.
    But if I open the throttle to max, it eventually cuts out violently, then lunges forward, cuts out, lunges, etc. - until I reduce the throttle again to midspeed. Sometimes it cuts out completely at speed too, and I have to restart it.
    Is this an electrical or computer/sensor issue? Or water in the fuel?
    Thinking/hoping it might be water in the fuel, I drained the fuel tank through the fuel sender hole, hopefully I got out all the fuel. For the last bit I used a shop vac and sucked it up, but not sure if there's a hidden reservoir somewhere that I missed.
    Next step is to figure out if the Merc240EFI has a fuel filter and a water separator. If so, can someone tell me where they are located, as I don't see them. I only see the fuel lines connected directly to the engine.
    Help please... Is it water in the fuel, or something else?
    Thanks in advance,
    Andrew
    2002 Seadoo Utopia 205 Merc 240EFI with Bennett Hydraulic Trim Tabs
    1997 Seadoo GTX with Touring Windshield
    1995 Seadoo GTS with Touring Windshield
    0 Not allowed!
  7. #6
    rookie101's Avatar
    Join Date
    Jun 2008
    Location
    Okotoks Alberta, Canada
    Posts
    1,012
    Watercrafts
    2006 Yamaha AR230 HO 320hp
    Thumbs Up
    Received: 4 Given: 0
    Default Fuel/water seperator
    You have two filters on your engine, there is a small inline fuel filter, and a fuel water separator. The fuel water separator looks like a spin on oil filter with the addition of a water sensor that threads into the bottom of it.
    To change the filters' I cut the bottom off a washer fluid, or antifreeze jug and have a bucket handy. (I know..... What's the bucket for??) Start by sliding the bottom of the cut off jug under the fuel/water separator, and remove the water sensor to let the fuel drain. Once it has stopped dripping dump the jug bottom in the bucket. (oh that's what its for!!) you can now get on the separator with a filter wrench and remove it. Reinstall in the reverse order. Now place the jug bottom under the small inline filter and remove and replace it. Throw the jug bottom in the bucket and your done.
    Since you are in there, I would also change the spark plugs at the same time. Give this a try and get back to us with an update.
    fuel/water separating filter Mercury part number 35-18458Q4
    inline fuel filter Mercury part number 35-889615
    Ngk plug number BPZ8HS10 (do not substitute)
    Aaron
    0 Not allowed!
  8. #7
    Junior Member
    Join Date
    Feb 2009
    Location
    Texas
    Posts
    17
    Watercrafts
    Thumbs Up
    Default
    Aaron, thanks, I will try to do it this weekend.
    But can you tell me exactly where is the water separator and the inline fuel filter are located? I've looked all over the engine and can't see it.
    On the Merc sterndrive on my previous boat, it was obvious - was connected right to the engine with the fuel line coming into it. But on the 240 EFI, I just don't see the spin-on water separator filter. Nor do I see the inline fuel filter.
    thanks!
    Andrew
    0 Not allowed!
  9. #8
    Join Date
    Apr 2008
    Location
    Virginia
    Posts
    39
    Watercrafts
    2003 Sea Doo Sportster and 2001 Sea Doo Utoipa
    Thumbs Up
    Default Crank Position Sensor.
    I know this problem all to well. My enginge did the same exact thing. It turned out to be the CPS that is mounted in front if the teeth on the fly wheel real simple fix, less than 5 miniutes, just two screws unplug it put the new one in $50 and your off. I'm so confident I would put money on it.
    0 Not allowed!
  10. #9
    Junior Member
    Join Date
    Feb 2009
    Location
    Texas
    Posts
    17
    Watercrafts
    Thumbs Up
    Default
    Many thanks Chrisca74 - I'm really hoping you're right - that would be an easy fix, going to look into it this weekend.
    Any chance you can tell me what it looks like and how I access it. Is it on top of the engine near the front?
    Thanks again.
    0 Not allowed!
  11. #10
    Join Date
    Apr 2008
    Location
    Virginia
    Posts
    39
    Watercrafts
    Thumbs Up
    Default Cps
    That is correct, it is on the top of the engine held in place with 2 bolts and it has I belive a 2 wire plug. Its right below the fly wheel it monitors the teeth on the fly wheel. Let me know how it turns out.
    0 Not allowed!
  12. #11
    Junior Member
    Join Date
    Feb 2009
    Location
    Texas
    Posts
    17
    Watercrafts
    Thumbs Up
    Default Problem appears to be solved - thx.
    Thanks all for the advice. It appears to have been solved. I changed the inline fuel filter, the fuel filter/water separator and cleaned the spark plugs.
    I just took it out on the lake and the hesitations and cutouts seems to have gone away. Hopefully it will stay that way.
    One note is that when I emptied the fuel filter/water separator into a plastic container, there were quite a lot of sediment in there.
    Chrisca74 - thx also for the suggestion on the CPS. I went to the dealer, didn't have my serial number with me, so they gave me the CPS they had in stock. But when I looked on my 240 EFI engine, I couldn't find that part. Looked it up on Mercruiserparts.com with my serial number and there doesn't appear to be a CPS on this model with my serial number (I did notice it on other models though.
    Thanks again for the suggestions/advice, appreciated.
    0 Not allowed!
  13. #12
    Junior Member
    Join Date
    Jun 2008
    Location
    Ireland
    Posts
    9
    Watercrafts
    1996 seadoo xp 2000 seadoo challenger
    Thumbs Up
    Default 240 EFI Mercury engine keeps cutting out and hard to start
    Hi im gaving problems with my 2000 seadoo challenger. It cut out on me a few times in mid run but after it cut out it would not start for ages. when out on the river and i turn off the boat it can also take ages for it to start you i could be there for about 10 mins trying to start it. I change the sprk plugs in the boat and there still was no change and this stage i cant trust the boat been towed in 2 many times now. Any suggestions would be great
    0 Not allowed!
  14. #13
    Senior Member seadoodude1's Avatar
    Join Date
    Oct 2008
    Location
    Cypress, TX
    Posts
    163
    Watercrafts
    1998 Seadoo GSXL & 2000 Seadoo Challenger 2000
    Thumbs Up
    Received: 1 Given: 0
    Default
    This seems to be a common problem and I'm still searching for answer. In my case engine will cut off but can be immediately restarted. Cots out more frequently in rough choppy water. I ordered new plugs and exhaust hose and trigger. Now I see it may be CPS. something else to try before she sees the mechanic.
    0 Not allowed!
  15. #14
    Junior Member
    Join Date
    Feb 2009
    Location
    Texas
    Posts
    17
    Watercrafts
    Thumbs Up
    Default
    Seadoodude1, your problem might be the post where the DESS key connects to. I had that problem on my 97 GTX seadoo, it would just cut out while driving, then start right up after I took the DESS key off and put it on again. If that's the problem, just buy a new post at the dealer and then you can cut the wires and replace it.
    Back to my Utopia 205, which appeared to be fixed in Feb09 - the acceleration problem is back:
    "When just above idle, the engine suddenly cuts out, then comes back, then cuts out. Sometimes it cuts out completely and I have to restart it. When it comes back, it lunges forward obviously, then cuts back again.
    But if I open the throttle to max, it eventually cuts out violently, then lunges forward, cuts out, lunges, etc. - until I reduce the throttle again to midspeed. Sometimes it cuts out completely at speed too, and I have to restart it."
    The problem just started again, so I emptied the fuel filter/water separator, and put in new spark plugs, but haven't tried it yet.
    Could the problem be the throttle shifter? There is a magnet in the shifter that activates a switch, and when I put it into forward or reverse, it often doesn't activate - so when I throttle-up, the rev limiter goes on. I then whack right next to the shifter a few times, and then try again, and after 2-3 times it usually engages.
    I'm wondering if the magnet is suddenly disengaging and then re-engaging when I'm going at high speed, which causes the lunging.
    Any thoughts/advice? Thanks.
    2002 Seadoo Utopia 205 with Bennett Trim Tabs
    1997 Seadoo GTX
    1995 Seadoo GTS
    0 Not allowed!
  16. #15
    rookie101's Avatar
    Join Date
    Jun 2008
    Location
    Posts
    1,012
    Watercrafts
    Thumbs Up
    Default
    Andrew your problem definitely sounds like it is related to the neutral safety switch. Replace it and see if it cures the problem.
    Seadoodude your problem being more pronounced in rough water sounds like a bad connection. Check your lanyard kill switch with a multimeter while banging on it, and check all the wires coming from your ignition switch. They can be problematic as well. Also be sure to check every connection you can find.
    Aaron
    Looking for parts for your Doo?? Click HERE
    Find your Mercury M-2 motor and pump parts here!
    0 Not allowed!
  17. #16
    Senior Member johnhibbs's Avatar
    Join Date
    Jul 2009
    Location
    San Diego
    Posts
    239
    Watercrafts
    SeaDoo Challenger 2000, year 2001, 240 EFI
    Thumbs Up
    Default Starts fine but won't go above 3000 rpm
    I recently had a problem with my Challenger 2000 240EFI M2. I tried everything on the engine then discovered that the wet exhaust hose was delamintated on the inside and was causing an exhaust blockage. I could always start the boat and it would run fine up to about 3000 rpm but no more. Does the exhaust hoses feel soft at the bend near the muffler? The exhaust hose should be very stiff. Unfortunately you have to remove the hose and look inside to be sure it's not delaminated. Seadoo had a recall because of these hoses and has a new design now. You may have to cut a slit in the hose at the engine end to get it off because it is probably melted on. I'm on a mission to tell everyone about this problem. The delaminated hose looks like the one on the left when you open it up.
    0 Not allowed!
  18. #17
    Junior Member
    Join Date
    Feb 2009
    Location
    Texas
    Posts
    17
    Watercrafts
    Thumbs Up
    Default
    Wow John that's pretty interesting - I haven't checked the exhaust hoses to see if they've delaminated - I will check them when I return from vacation mid August.
    However if it's a recall, can I bring my boat into a Seadoo dealer and they should check/fix that for free?
    I'm seriously wondering if that could be the issue. I'm not absolutely convinced it's the neutral switch, because when it last happened the other day, I had the engine at full throttle, and it lost some power at the top end just before I had to come in. The boat slowed down to 46mph from 48, and I could hear the engine wasn't going as fast as it had a minute earlier, even though it was not lunging at this time.
    So I'm wondering if the tubes became delaminated and were restricting the exhaust. I'll have to check this when I get back home.
    Aaron - thanks for the input as well. I see you're in Calgary - my brother and some family live in Edmonton, and I'm originally from Montreal, now in Texas. Where do you ride your boat in Calgary?
    Thanks guys.
    Andrew
    0 Not allowed!
  19. #18
    Join Date
    Jul 2009
    Location
    San Diego
    Posts
    239
    Watercrafts
    Thumbs Up
    Default Seadoo recall
    The way I understand it is that the hoses would get a small leak and spray the engine compartment with a mist of salt spray. This salt would then cause a problem with corrosion on the throttle and put it in WOT. I don't think they recalled the hoses but they did redesign the hoses. The recall was to replace the throttle parts. This is the recall: http://www.uscgboating.org/recalls/r...spx?id=040019T
    I hear the new hose also has a problem but it should last a while. The new hose has a metal liner.
    Both of my wet exhaust hoses were delaminated on the inside.
    0 Not allowed!
  20. #19
    Join Date
    Jul 2009
    Location
    San Diego
    Posts
    239
    Watercrafts
    Thumbs Up
    Default For our Canadian friends, 240EFI recall
    0 Not allowed!
  21. #20
    Junior Member
    Join Date
    Feb 2009
    Location
    Texas
    Posts
    17
    Watercrafts
    Thumbs Up
    Default Spark plugs may have been the problem...
    Well, I emptied the fuel filter/water separator, but did not see any water in it.
    So I decided to replace the spark plugs with new NGK BPZ8HS-10 ($5.49 each at O'Reilly Auto is the lowest I could find them).
    Seems to have fixed the problem - for now... Hesitations went away at low and high speed. Seems to idle fine as well.
    0 Not allowed!
  22. #21
    Junior Member
    Join Date
    Sep 2010
    Location
    new york city
    Posts
    5
    Watercrafts
    sea doo challenger 2000, model 2002 sea doo gti 1997
    Thumbs Up
    Default
    hi, i own a sea doo challenger 2000, model 2002 with a mercury efi 240 hp, the engine run great untill this summer when i try to accelerate about middle range, the engine stop, it only runs in low or very high speed, if i put the trotle in the middle the engine dies and it take a while to start again, also, i don't know if is related but all the gauges stoped working at the same time, i cheked all the fuses and they are ok, coul be the cps?. please help
    0 Not allowed!
  23. #22
    Join Date
    Jul 2009
    Location
    San Diego
    Posts
    239
    Watercrafts
    Thumbs Up
    Default exhaust hoses
    I had a problem with my exhaust hoses shutting down the engine. These hoses delaminate on the inside and block the exhaust at high rpm. Do the hoses feel soft? Can you squeeze the hose together? They should be very stiff. See my previous posts above.
    0 Not allowed!
  24. #23
    Junior Member
    Join Date
    Sep 2010
    Location
    new york city
    Posts
    5
    Watercrafts
    Thumbs Up
    Default
    i don't think the hose is the problem because the engine works fine at high speed, it just at mid speed that shut off.
    0 Not allowed!
  25. #24
    Junior Member
    Join Date
    Jan 2011
    Location
    Florida
    Posts
    2
    Watercrafts
    2000 islandia
    Thumbs Up
    Default
    Quote Originally Posted by carlosparham View Post
    Carlos, did you fix the problem? Im having the same issue right now and cant seem to figure it out. I just replaced the plugs and both filters. Took it out today and its doing the same thing. Any suggestions would be greatly appreciated.
    Thanks, Ricky
    0 Not allowed!
  26. #25
    Junior Member
    Join Date
    Sep 2010
    Location
    new york city
    Posts
    5
    Watercrafts
    Thumbs Up
    Default
    No, i haven't fix it, the problem that i have is that in Honduras, where the boat is, there is not a Sea Doo dealer or mechanic that i can take my boat to, so basicaly i need to fix it myself, if only i knew what the problem is, now something odd is happening, all the gauges are not working, not one of them, i tough it was an electrical problem but i cheked all the fuses and are fine, i just don't know what is happening, first the engine now the gauges, if you ever find the solution please let me know, i will really appreciated. thank you
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. One long beep, engine shuts off ???
    By krusch in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 08-31-08, 09:03 AM
  2. help!! '95XP 587 engine - runs 30 minutes - gets hot - shuts down
    By uncle walt in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-30-08, 01:57 PM
  3. engine shuts down
    By oldman1958 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-22-08, 12:03 PM
  4. high speed jet
    By jerryjoe in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-12-08, 10:45 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
