winterizing your boat??? - Seadoo Forums
Visit PWCMuscle.com
for 15% off all Hydro Turf - CODE: HYDRO15
Results 1 to 7 of 7
  1. ☑ ORIGINAL POSTER #1
    Junior Member
    Join Date
    Aug 2008
    Location
    tennessee
    Posts
    1
    Watercrafts
    1999 1800 seadoo challenger 1993 3 seater seadoo gtx
    Thumbs Up
    Received: 0 Given: 0
    Question winterizing your boat???
    HI all!! I need some info from anybody that would know how to winterize a 1999 1800 seadoo challenger. This is my first Jet boat and I'm not to familiar with the mechanics.
    0 Not allowed!
  2. # ADS
  3. #2
    Join Date
    Nov 2007
    Location
    United States
    Posts
    146
    Thumbs Up
    Default Winterizing....?
    There is an excellent "sticky" in the "how-to" thread above on how to winterize your boats........'
    Just look up there, it's step by step.
    0 Not allowed!
  4. #3
    kustomkarl's Avatar
    Join Date
    Sep 2007
    Location
    Sunny S.W. coast of Englewood, Florida
    Posts
    11,229
    Watercrafts
    1996 Chris Craft 26' Cruiser, Kawasaki 440 Superstock, 550 Mod., 2008 200Speedster 310 Hp
    Thumbs Up
    Received: 12 Given: 0
    Default
    Seadoo Winterizing
    This is what you need to do to winterize your 2 Stroke Seadoo.
    1) Insert fuel stabilizer in fuel tank. Make sure you have the proper mix ratio and rock the boat to mix it with gas.
    2) Plug in the water hose in the back of the boat (not on the top because you will need to pinch some hoses to do it right). Start engine and let run for 4-5 minutes to get the stabilizer in the engine.
    3) Use SEA-DOO LUBE (This is what seadoo recommends, and is made for this purpose) and spray inside the air intakes for at least 30-40 seconds. What I do is I spray the lube inside until the engine dies, then I know it's in there everywhere.
    4) Remove spark plugs and spray SEA-DOO LUBE inside the holes. Don't be shy to use the stuff. Screw back the plugs in.
    TIP: If you use the small red tube, hold onto it so it won’t fall into the engine.
    5) Remove the gray cover on the PTO and grease the shaft (you will see the grease fittings after you remove the gray cover).
    6) Now for the tricky part, adding the antifreeze. Be sure to use anti freeze made for aluminum block engines. You need to follow the service manual method exactly. The service manual says to pinch hoses, and insert the fluid from the top water line. On some models you needed to pinch 4 hoses. What I did is buy vice-grips with smooth jaws ($5.00 usd each). Fill it with around 2 liters of antifreeze, un pinch one hose, put another 6 oz., wait, then remove the vice-grips. Almost all the fluid will then come out at the bottom. The idea is to mix the antifreeze with whatever water was in the cooling system, so it doesn't freeze.
    A service manual is a must and will be cheaper than if you get the engines winterized, so it's a definite good investment. It has pictures and detailed instructions for just about everything you need. I don't want to say what hose to pinch because it's different for each model. I recommend you join as a “Premium Member” to get your service manual and if you still have questions you could get advice from the forum’s expert moderators.
    You also need to change the oil in the Jet Pump, incase it has water in it. Ask me for information and I’ll post it for you, as it is a bit much to post here in this post.
    I hope this helps.
    Karl
    Please, If you have a "troubleshooting" request, use the correct category in the Sea-Doo Forum first.
    "Premium / Subscribed Members", not getting an answer, pm me directly for Expert Advise.
    When your ready for more performance, click on the this link!
    Click to order your Sea-Doo Parts at a fair price.
    Click here to view/join our Group on "Face Book"
    0 Not allowed!
  5. #4
    Junior Member
    Join Date
    Sep 2008
    Location
    Canada
    Posts
    3
    Watercrafts
    2001 Challenger 2000
    Thumbs Up
    Default
    I joined as a member to get this manual that shows what hoses to clamp -
    I have a 2001 challenger 2000 - I have both owners manual and the M2 jet service manual - there is no mention of having to put antifreeze through the system in these manuals - what am I missing - is there another service manual that has the proceedure in this forum?
    Sorry first boat - I think I know which lines to clamp - but would like some confirmation - don't need a cracked block like my neighbour got last year
    0 Not allowed!
  6. #5
    Member wayne99's Avatar
    Join Date
    Oct 2008
    Location
    Langdon, Alberta
    Posts
    43
    Watercrafts
    2000 Sea-doo Challenger 2000 240 EFI M2 Jet Drive
    Thumbs Up
    Default
    I am planning on putting antifreeze in the water line attachment until I see it come out of the jet. This is what I have been doing for years with all of my PWC's and never had a problem for 8 years that I owned them. My Challenger is in a heated garage right now and has not run since late September. I am thinking most water has evaporated anyways.
    I also plan to fog the motor and take out the battery. I am not adding fuel stabalizer as I think it does more harm then good. I'll simply top my tank up with premium in the spring and run the tank close to an 1/8 before I refill.
    If someone strongly disagrees with this please let me know as I plan to winterize anyday now so I can claim my garage back. This is my first jetboat. I am a PWC guy until 08.
    Thanks,
    Wayne
    0 Not allowed!
  7. #6
    seadoosnipe's Avatar
    Join Date
    Sep 2007
    Location
    Deep South
    Posts
    9,841
    Watercrafts
    1997 Challenger, 1997 GTX , 1991 SP and a shop with 2 spare 787cc's and a bunch of parts laying arou
    Thumbs Up
    Received: 68 Given: 0
    Default Merc....
    The Merc engine has a totally different set up and is designed to lose all water when you pull it out of the water. The Rotax is a TLCS (total loss cooling system) too, but it seems water pockets remain in a few areas.
    Your procedure for winterizing sounds fine. My favorite saying is "there is always more ways than one to skin a coon". So, in winterizing, I don't think that one way is better than anohter. As long as you get some in the system. I don't use it on my boat. I do my two skis because I don't mess with them much through the winter (although it only freezes 2 or 3 times a year) but I work on and run my boat on a regular basis in the off season. I have to tinker with everything........
    Looking for tips and advice, researched articles on carbs, spark plugs and general maintenance can be found at Snipes Korner. You can also follow me on "Twitter".
    Quality parts at low prices, visit Seadoowarehouse right here in our own forum. Please PM me if you are having a problem finding what you need!
    Is your jet ski fast? Do you want your XP or RXP to stand out? I know a place that has what you need to make it faster. Make your jetsksi a muscle craft, not just the ordinary, standard stock ski.
    Seen my GTX?... Those awesome graphics can be purchased from JetSki Detailing. Tell them Seadooforum sent you.
    Ever wonder what the inside of your 787cc engine looks like. Want to identify the parts, check out my thread on the 787. I'm sure there is something for everyone who want to learn about the internal parts.
    0 Not allowed!
  8. #7
    rookie101's Avatar
    Join Date
    Jun 2008
    Location
    Okotoks Alberta, Canada
    Posts
    1,012
    Watercrafts
    2006 Yamaha AR230 HO 320hp
    Thumbs Up
    Received: 4 Given: 0
    Default
    wayne99, the only other thing I would suggest with the Mercury M2 is change the jet pump oil. Just put the shifter in the forward position, and you can see the drain and fill plugs through the pump outlet. Mercury recommends you do it once a year, so I just do it as part of winterizing.
    Aaron
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Winter and De-Winterizing your Boat
    By hfgreg in forum How-To Tech Articles
    Last Post: 11-02-11, 11:27 PM
  2. Winterizing
    By seadoo7 in forum 4-Tec Sea-Doo PWC Forum
    Last Post: 08-02-08, 09:38 PM
  3. Winterizing
    By Stevie in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 09-30-07, 10:30 PM
  4. How much winterizing do I need?
    By harrywillingham in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 09-22-07, 02:53 AM
  5. Winterizing a 2005 Seadoo Speedster Boat
    By MikedavidSR in forum 4-Tec Sea-Doo Boats
    Last Post: 09-18-07, 07:39 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
