Loss of Power - Seadoo Forums
Visit PWCMuscle.com
for 15% off all Hydro Turf - CODE: HYDRO15
Results 1 to 12 of 12
Thread: Loss of Power
  1. ☑ ORIGINAL POSTER #1
    Junior Member
    Join Date
    Aug 2008
    Location
    Rochester, NY
    Posts
    16
    Watercrafts
    1995 Seadoo Speedster
    Thumbs Up
    Received: 0 Given: 0
    Default Loss of Power
    I am hoping someone can help me diagnose a problem with my 1995 Seadoo Speedster. I purchased the boat a couple of months ago and it ran great for about 3 weeks. All of a sudden one of the engines would start out about 7000-7500 rpm's at full throttle, run for about 10 seconds and then drop down to 4000 rpm. For a while it would sporadically kick back up to 6500 rpm but then drop back down to around 4000 rpm. Now it only will run at 4000 rpm's. Any ideas? Thank you.
    0 Not allowed!
  2. # ADS
  3. #2
    Join Date
    Jul 2007
    Location
    San Jose, CA
    Posts
    889
    Watercrafts
    1996 HX (Owner) 1996 GTX (Steward) 1996 GSX (Guest Steward)
    Thumbs Up
    Received: 10 Given: 0
    Default
    Start here->http://www.seadooforum.com/showthread.php?t=5563
    A quick check is to run with the fuel selector to Reserve and see if it runs differently. Otherwise you need to inspect the entire fuel system (not just the filter bowl - need to dig into the internal filters on the carbs).
    With a boat of this age, you should consider becoming a Premium Member for access to the detailed shop manuals. These manuals will help you maintain your Speedster for DIY projects or help you visualize any work the dealer does for you.
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Junior Member
    Join Date
    Aug 2008
    Location
    Rochester, NY
    Posts
    16
    Watercrafts
    Thumbs Up
    Default
    Why would it make a difference on reserve? Someone at a local shop mentioned a possible wear ring problem? Is that a possibility?
    0 Not allowed!
  5. #4
    Experienced Rider
    Join Date
    Aug 2008
    Location
    Vegas
    Posts
    360
    Watercrafts
    1996 Challenger 14
    Thumbs Up
    Default
    Another thing it could maybe be is the neutral safety switch... on my challenger if the switch sticks on, it keeps the motor from revving over 3500 rpm...
    easy way to check, when its doing it, try to start it with the gear selector in forward, it should only start in neutral, and should give you a 4-beep error code if its not in neutral.
    0 Not allowed!
  6. #5
    Experienced Rider
    Join Date
    Aug 2008
    Location
    Vegas
    Posts
    360
    Watercrafts
    1996 Challenger 14
    Thumbs Up
    Default
    I think what he is talking about with reserve fuel is that the fuel delivery may be obstructed/clogged. Switching to reserve uses a different fuel path for part of the distance.
    The wear ring idea has to do with cavitation. If you accelerate to 4/5000 rpm and then the engine bounces about between that and redline and the boat doesn't go any faster, it is cavitating.
    Cavitation occurs when the flow of water into the pump is somehow obstructed. If the wear ring is damaged, it can cause turbulence in the water causing the cavitation.
    0 Not allowed!
  7. ☑ ORIGINAL POSTER #6
    Junior Member
    Join Date
    Aug 2008
    Location
    Rochester, NY
    Posts
    16
    Watercrafts
    Thumbs Up
    Default
    I have also noticed that when it is in forward with no throttle it makes a loud continuous beep. I have checked the intakes and there are no obstructions. How can I check to see if the wear ring is worn? Is it something easy to see. I know where it is located, however what do I look for? Also if it is a fuel problem how difficult is it to get to the smaller filters in the carbs? Thanks.
    0 Not allowed!
  8. #7
    Experienced Rider
    Join Date
    Aug 2008
    Location
    Vegas
    Posts
    360
    Watercrafts
    1996 Challenger 14
    Thumbs Up
    Default
    A continuous beep indicates an overheat condition. If revving up causes it to stop beeping, there might be a minor obstruction in the water intake... Is the boat on a trailer? Take a look around the intake grate. Maybe a stick got sucked up or a fish tried to swim up there
    Also try that weedless lever under the dash. I have no idea how it works, i think its supposed to open the intake grate for you but I'm not sure...
    0 Not allowed!
  9. ☑ ORIGINAL POSTER #8
    Junior Member
    Join Date
    Aug 2008
    Location
    Rochester, NY
    Posts
    16
    Watercrafts
    Thumbs Up
    Default
    It is on a trailer right now-I have crawled underneath and there are no obstructions.
    0 Not allowed!
  10. #9
    Join Date
    Jul 2007
    Location
    San Jose, CA
    Posts
    889
    Watercrafts
    Thumbs Up
    Default
    A bad wear ring is like a bad slipping clutch on a car - you get tons of revs, but no speed.
    If you can't make the engine turn above 4000rpm, then the wear ring is not a major factor. Probably more of a problem with fuel at the engine. Possibly some type of ignition issue, but check fuel first.
    0 Not allowed!
  11. ☑ ORIGINAL POSTER #10
    Junior Member
    Join Date
    Aug 2008
    Location
    Rochester, NY
    Posts
    16
    Watercrafts
    Thumbs Up
    Default
    JPX,
    How hard is it to change the filters located in the carbs?
    Thanks
    John
    0 Not allowed!
  12. #11
    Banned
    Join Date
    May 2008
    Location
    inland empire, CA
    Posts
    5,084
    Watercrafts
    99' Seadoo Speedster
    Thumbs Up
    Received: 6 Given: 0
    Default
    not difficult at all, if anything, use masking tape, for assurance, and tape/mark each hose/cable line while remove'n...
    0 Not allowed!
  13. ☑ ORIGINAL POSTER #12
    Junior Member
    Join Date
    Aug 2008
    Location
    Rochester, NY
    Posts
    16
    Watercrafts
    Thumbs Up
    Default
    Do you have to re-adjust the carbs if you remove the filters?
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. 1999 GS loss of power
    By TonyBro in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-30-08, 10:09 PM
  2. 98 Gts Loss Of Power Top End
    By tnjetski in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 06-01-08, 12:02 PM
  3. Islandia loss of power
    By capitolgator in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 05-21-08, 07:56 PM
  4. loss of power
    By flhxsei in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 05-19-08, 12:46 PM
  5. power loss
    By Robert in forum Non-Seadoo PWC Talk
    Last Post: 06-26-07, 11:42 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
