P-Fault codes... - Seadoo Forums
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 1 of 1
  1. ☑ ORIGINAL POSTER #1
    seadoosnipe's Avatar
    Join Date
    Sep 2007
    Location
    Deep South
    Posts
    9,852
    Watercrafts
    1997 Challenger, 1997 GTX , 1991 SP and a shop with 2 spare 787cc's and a bunch of parts laying arou
    Thumbs Up
    Received: 78 Given: 0
    Default P-Fault codes...
    I got this list of P codes that I wanted to share with those looking for them, but having a problem either finding their meaning or what all they cover.
    To get a list of stored codes from your computer, for 4TEC skis up to 2003: with the engine off, plug in your lanyard and hit SET 5 times. If nothing happens you need a dealer to read the codes. Here is a list of what they mean, if any come up:
    Here is the list of trouble codes displayed on all Sea-Doo 4-stroke 4-TEC equiped skis. It will take a dealer and parts to cure most of these, but it at least gives you an indication of the fault, and sometimes you can replace the part yourself.
    P-Fault Codes:
    P0106
    Manifold atmospheric presure sensor out of range
    P0107
    Manifold atmospheric presure sensor or Manifold barometric presure sensor shorted to ground
    P0108
    Manifold atmospheric presure sensor or Manifold barometric presure sensor shorted to 12V or open circuit
    P0111
    Intake manifold temp sensor faulty
    P0112
    Intake manifold shorted to ground
    P0113
    Intake manifold shorted to 12V or open circuit
    P0116
    Engine temp sensor faulty
    P0117
    Engine temp sensor shorted to ground
    P0118
    Engine temp sensor shorted to 12V or open circuit
    P0122
    TPS out of range - short to ground
    P0123
    TPS out of range - short to 12V or open circuit
    P01231
    Fuel pump shorted to ground or open circuit
    P0232
    Fuel pump shorted to 12V
    P0261
    #1 injector short to ground or open circuit
    P0262
    #1 injector shorted to 12V
    P0264
    #2 injector short to ground or open circuit
    P0265
    #2 injector shorted to 12V
    P0267
    #3 injector short to ground or open circuit
    P0268
    #3 injector shorted to 12V
    P0236
    Knock sensor out of range
    P0336
    Crank position sensor - wrong RPM detected
    P0337
    No CPS signal, but CAPS signal detected
    P0339
    Crank signal fault not plausible with cam signal
    P0344
    Cam phase sensor signal missing
    P0351
    Ignition coil #1 open circuit or shorted to ground or to 12V
    P0352
    Ignition coil #2 open circuit or shorted to ground or to 12V
    P0353
    Ignition coil #3 open circuit or shorted to ground or to 12V
    P0461
    Fuel level sensor circuit out of range
    P0462
    Fuel level sensor shorted to ground
    P0463
    Fuel level sensor circuit shorted to 12V or open circuit
    P0505
    DLA output stage cutoff memory cuircut or output stage fault or open circuit or short to 12V
    P0513
    Incorrect DESS key
    P0520
    Oil pressure switch faulty
    P0544
    Exhaust gas temperature sensor fautly
    P0545
    Exhaust gas temperature switch shorted to ground
    P0546
    Exhaust gas temperature switch shorted to 12V or open circuit
    P0562
    Battery voltage too low
    P0536
    Battery voltage too high
    P0600
    CAN communication problem detected by EMS or MPEM
    P0601
    TPS learns unlikely or checksum fault
    P0602
    ECU not coded
    P0604
    RAM faulty
    P0605
    EEPROM faulty
    P0605
    Checksum fault EEPROM
    P0608
    Sensor 5V power supply short to ground
    P0608
    Sensor 5V power supply short to 12V
    P0616
    Starter relay short to ground or open circuit
    P0617
    Starter relay short to 12V
    P1102
    TPS adaption failure
    P1104
    TPS adaption cancelled
    P1148
    Fuel injector 1,2 or 3 - safety fuel cutoff disabled
    P1200
    Blow-by valve shorted to ground or open circuit
    P1201
    Blow-by valve shorted to 12V
    P1202
    Oil tank pressure switch implausible or blow-by valve still closed
    P1517
    Compass out of range
    P1590
    VTS position sensor out of range
    P1591
    VTS position sensor - low voltage
    P1592
    VTS position sensor - high voltage
    P1593
    VTS malfunction
    P1607
    MPEM fault
    P1675
    Spare output 1 shorted to ground or open circuit
    P1676
    Spare output 1 shorted to 12V
    P1678
    Spare output 2 shorted to ground or open circuit
    P1679
    Spare output 2 shorted to 12V
    P1680
    Comminication problem detected by MPEM
    P1681
    Communication problem - instrument cluster message missing
    P1682
    Communication problem - EMS message missing
    P1683
    COM RAM fault
    P1690
    VTS control up circuit open circuit or shorted to ground
    P1691
    VTS control up circuit shorted to battery
    P1692
    VTS control down circuit open circuit or shorted to ground
    P1693
    VTS control down circuit shorted to battery
    P0344, P1200
    Burnt TOPS 10A fuse
    P1675
    Burnt depth gauge or spare 2A fuse
    P0353, P0267
    Burnt cylinder #3 ignition coil and injection 10A fuse
    P0352, P0264
    Burnt cylinder #2 ignition coil and injection 10A fuse
    P0351, P0261
    Burnt cylinder #1 ignition coil and injection 10A fuse
    P1680, P1681
    Burnt information center 1A fuse
    P0616
    Burnt Bilge pump, beeper, diagnostic center 3A fuse
    P1678
    Burnt spare 5A fuse
    P0231
    Burnt starter, fuel pump 10A fuse
    P0600
    Burnt MPEM 2A fuse
    P1690, P1692
    Burnt VTS 7.5A fuse
    Looking for tips and advice, researched articles on carbs, spark plugs and general maintenance can be found at Snipes Korner. You can also follow me on "Twitter".
    Quality parts at low prices, visit Seadoowarehouse right here in our own forum. Please PM me if you are having a problem finding what you need!
    Is your jet ski fast? Do you want your XP or RXP to stand out? I know a place that has what you need to make it faster. Make your jetsksi a muscle craft, not just the ordinary, standard stock ski.
    Seen my GTX?... Those awesome graphics can be purchased from JetSki Detailing. Tell them Seadooforum sent you.
    Ever wonder what the inside of your 787cc engine looks like. Want to identify the parts, check out my thread on the 787. I'm sure there is something for everyone who want to learn about the internal parts.
    0 Not allowed!
  2. # ADS
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Error Codes
    By PDGray in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-21-08, 11:19 PM
  2. P Codes
    By kbreither in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 05-13-08, 09:17 PM
  3. P-O505 Fault code on 2005 RXT
    By godzilla in forum 4-Tec Sea-Doo PWC Forum
    Last Post: 01-19-08, 05:16 PM
  4. 4tec Trouble Codes
    By Dennis in forum 4-Tec Sea-Doo PWC Forum
    Last Post: 11-23-07, 02:59 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
