Grey Fuel Line Replacement - Seadoo Forums
15% off Hydro Turf 10% off WSM Parts Email Sales@PWCMuscle.com
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 14 of 14
  1. ☑ ORIGINAL POSTER #1
    Junior Member
    Join Date
    Jul 2008
    Location
    Brampton, Ontario
    Posts
    7
    Watercrafts
    1996 GTX
    Thumbs Up
    Received: 0 Given: 0
    Default Grey Fuel Line Replacement
    So from everything I have heard and read from this site and others. The grey fuel lines need to be replaced with others. Can even use Napa fuel line hoses. I have a 96 GTX and have had two techs look at it in the past few weeks and both are very skeptical about having to replace the fuel lines at all. If they are to be replaced they are telling me that I would need to use Marine grade hose? Would really appreciate some direction and reasoning behind it.
    0 Not allowed!
  2. # ADS
  3. #2
    nswillin's Avatar
    Join Date
    May 2008
    Location
    Knoxville, Tn
    Posts
    1,061
    Watercrafts
    2000 SeaDoo XP
    Thumbs Up
    Default They suck
    If you pull those gray lines off you will see what everybody is talking about. The inside of those lines decompose and turn into a greenish blue nasty sludge which will clogg everything. Moderator JPX has some pictures of this.
    Best lines to use are fuel injection rated lines. Napa was the highest in price when I was buying, they were like $6.50/ ft. Autozone had them for $3/ft, that's where I bought mine. Gotta get new stainless steel clamps too.
    0 Not allowed!
  4. #3
    Join Date
    Jul 2008
    Location
    Tri-Cities, WA
    Posts
    34
    Watercrafts
    1996 Seadoo XP
    Thumbs Up
    Default
    I just replaced my fuel lines last week with the reg. black automotive fuel lines from NAPA cost about $1.50 / FT and they work just fine my xp runs alot better
    0 Not allowed!
  5. #4
    Join Date
    Jun 2008
    Location
    San Antonio, Texas
    Posts
    92
    Watercrafts
    1997 GTS Sea-Doo
    Thumbs Up
    Received: 1 Given: 0
    Default
    i used the regular hose as well when i replaced mine and have had no problems so far after running about 40 gallons of gas through it. just fyi.
    0 Not allowed!
  6. #5
    Join Date
    Jul 2007
    Location
    San Jose, CA
    Posts
    889
    Watercrafts
    1996 HX (Owner) 1996 GTX (Steward) 1996 GSX (Guest Steward)
    Thumbs Up
    Received: 10 Given: 0
    Default
    The truly correct hose to replace the grey fuel hoses with is....well, NEW grey fuel hose made by the original manufacturer Tempo.
    But we saw how that turned out a few years later, right?
    I used NAPA's basic fuel hose. I suppose Marine grade fuel injection hose would be considered top of the line. But I have since lowered my standards quite a bit resulting in a more frugal decision to go with the regular non-FI hose.
    You can always put the baddest of the baddest hose in there. But I think it is overkill. Only you and your own wallet can make that decision.
    0 Not allowed!
  7. #6
    Junior Member
    Join Date
    Jun 2008
    Location
    Dracut, Mass
    Posts
    22
    Watercrafts
    96 XP 800
    Thumbs Up
    Default
    I used regular 1/4 in fuel line from the local auto parts store and it works great. Pretty easy to do too. I would clean out the fuel selector switch and the filters inside of the carbs too.
    0 Not allowed!
  8. #7
    Member markrvp's Avatar
    Join Date
    Jun 2008
    Location
    Granbury, TX
    Posts
    56
    Watercrafts
    2005 RXP 1997 GTX
    Thumbs Up
    Default
    I used 1/4" black EFI hose from NAPA. It was $1/foot. So far it has worked perfectly. I did a lot of looking around on this subject a month or so ago and didn't find anyone who was adamant that you have to use Marine hose.
    0 Not allowed!
  9. #8
    Experienced Rider
    Join Date
    Jul 2008
    Location
    Arkansas
    Posts
    621
    Watercrafts
    Old boat, got motor running, 1972. With 1971 4 cylinder merc on back. Runs good now! 1998 Sea Doo G
    Thumbs Up
    Default If you don't replace the gray hose
    Then you will be infusing your fuel system with a form of vinyl glue, and your troubles will never cease.
    There is no point to such a self destructive activity, unless you prefer working on it, to riding it!
    Nate
    I love all things mechanical.
    Nate
    0 Not allowed!
  10. #9
    Junior Member
    Join Date
    Jul 2008
    Location
    Norfolk, Va
    Posts
    7
    Watercrafts
    1997 GTI, 500 hours on the hull, Traded up for a 40 hour 2000 GTI. Also enjoy a 2005 Scout 222 Abaco
    Thumbs Up
    Default Just another opinion
    Don’t discount the safety factor. The manufactures’ of PWCs don’t use USCG rated A1 fuel lines because they “just want to”. It adds cost to their bottom line. They use it because it is a federal standard (i.e. law, 33 CFR sect 183.540). I understand that a lot of people have had issues with OEM fuel lines. I’m sure that most of those lines were manufactured prior to introduction of 10% Ethanol. I recently saw a TV (Ship Shape) show that is dedicated to boat maintenance. Fuel lines were a topic. They had mentioned that the A1 fuel line actually had a fire rating. I’m not an expert on the subject and I realize that PWC’s are exempt from some USCG requirements but I would never advise someone to deviate from OEM requirements. Chances are there will never be an issue using fuel line designed for a car or lawn mower. However, I would hate to be floating in the water watching my PWC burn to the water line because I decided to use something in a manner that it wasn’t designed to do just to save a couple of bucks……..
    0 Not allowed!
  11. #10
    Junior Member
    Join Date
    Jul 2008
    Location
    southern illinois
    Posts
    16
    Watercrafts
    95 Sea Doo XP 96 kawasaki STS 08 Sea Doo GTI
    Thumbs Up
    Default
    How many feet do I need to redo my 95 xp?
    0 Not allowed!
  12. #11
    Join Date
    Jun 2008
    Location
    San Antonio, Texas
    Posts
    92
    Watercrafts
    1997 GTS Sea-Doo
    Thumbs Up
    Default
    i used about 20 feet on mine and had some to spare but this was on a 97 gts though.
    0 Not allowed!
  13. #12
    Junior Member
    Join Date
    Jul 2008
    Location
    Virginia Beach
    Posts
    1
    Watercrafts
    95 Seadoo GTX
    Thumbs Up
    Unhappy all lines
    Quote Originally Posted by cordatta View Post
    As I look at the lines in my seadoo it seems that some of the grey lines seem to be air lines, though I may be wrong. Do I need to replace all the lines in my seadoo, or just the fuel lines?
    If so, will the 20 feet of lines cover it all?
    0 Not allowed!
  14. #13
    Join Date
    Jul 2008
    Location
    Watkins Glen, NY
    Posts
    32
    Watercrafts
    1994 Sea-Doo GTX 650
    Thumbs Up
    Default
    I just replaced mine on my '94 GTX. Bought 18' and had about 6" left over. I replaced all the vents and everything that was "grey". I used Autozone "not" FI rated 1/4" line that cost about $1.30/foot. I had the fuel tank and engine out for a rebuild so the job was easy. I suspect it is more difficult when both are installed.
    0 Not allowed!
  15. #14
    Join Date
    Jul 2007
    Location
    San Jose, CA
    Posts
    889
    Watercrafts
    Thumbs Up
    Default
    Bought way to much hose - a 25ft reel from NAPA. I changed the vent lines as well.
    To answer the previous question, the vent tubes don't really need to be replaced because of the deterioration. But I wanted a complete look and also to keep smart-aleck members from mentioning there were still grey hoses in my Seadoo every time I posted a pic!
    As far as the fire rating and such......you are absolutely right. USCG and various other sources most likely require manufacturers to use the marine grade gear. If I were renting my craft out or ran a shop, then this would be of utmost importance to me to maintain compliance and reduce liability.
    But this is no different than running speaker wiring for power on a car stereo amp - not correct, possible fire hazard, ghetto - but, hey it works. As long as Ford and Toyota aren't doing that crap when you buy the car from them, you can do whatever you want to your vehicle and still "get by".
    Based on all the things I dealt with on the water, fire is the more spectacular - but flooding and sinking my boat is a far more likely problem that I worry about when assessing risk.
    So don't take this as an endorsement of doing unsafe, illegal repairs to PWCs or boats. We're just suggesting that alternatives exist with "varying degrees of compliance."
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. What year did Sea doo Correct the grey fuel line issue?
    By twin051302 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-08-08, 11:30 AM
  2. 2000 Xp Grey Fuel Lines?
    By tresvatos1 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 06-25-08, 12:46 AM
  3. How much $$ for fuel line?
    By markrvp in forum Non-Seadoo PWC Talk
    Last Post: 06-23-08, 10:37 PM
  4. Grey fuel line?
    By ROC 87 in forum Non-Seadoo PWC Talk
    Last Post: 06-13-08, 07:35 PM
  5. Grey fuel hoses are bad, what about black ones? 99 747 engine Challenger 1800
    By car5car in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 03-06-08, 01:11 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
