Rotary Valve Cover Uneven Wear? - Seadoo Forums
15% off Hydro Turf 10% off WSM Parts Email Sales@PWCMuscle.com
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 6 of 6
  1. ☑ ORIGINAL POSTER #1
    Junior Member george0029's Avatar
    Join Date
    Jun 2012
    Location
    Chicago
    Posts
    10
    Watercrafts
    2013 SeaDoo GTI 130
    Thumbs Up
    Received: 0 Given: 1
    Default Rotary Valve Cover Uneven Wear?
    Hello All,
    I have a 2002 GTI LE into which I'm swapping a new SBT 717, but I'm a bit worried about the rotary valve cover. It isn't gouged or grooved anywhere, and the surface seems relatively smooth, but it seems to be wearing unevenly. Looking at the outside edge, the surface appears worn deeper near the intake manifold holes than elsewhere on the valve. Is this normal? I'd prefer to avoid replacing it, but I'm worried that uneven wear could cause some leaking between the two sides. Any input is appreciated, pics attached. Thanks Guys!
    0 Not allowed!
  2. # ADS
  3. #2
    Dr Honda's Avatar
    Join Date
    Apr 2009
    Location
    Pittsburgh
    Posts
    18,125
    Watercrafts
    '00 Polaris Genesis '96 XP800 '02 Islandia 240 EFI
    Thumbs Up
    Received: 332 Given: 0
    Default
    Normal... but if it's excessive, the cover should be changed.
    Tony
    PM or post for help. Don't leave questions in my profile box. (i never check it)
    I'm not going to be able to do vinyl or carbs for a while. Starting my new job is taking a lot of time
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Join Date
    Jun 2012
    Location
    Chicago
    Posts
    10
    Watercrafts
    2013 SeaDoo GTI 130
    Thumbs Up
    Default
    According to the manual, rotary valve clearance must be 0.30mm +/- 0.05 mm. My 0.35mm feeler gauge was a snug fit toward the center of the rotary valve, but clearance on the outside (near the uneven looking wear) was close to 1mm. Guess I'll have to order a RV cover from SBT for $120 shipped...... unfortunately they're out of stock and will take 3-5 days to ship, not to mention being closed on weekends.
    I'm wondering what could have caused such uneven wear. I blew my motor presumably due to a lean condition, which i attribute to a crack in the case on the rotary valve surface. The case broke at the upper left bolt that holds the RV cover in place, and cracked the surface of the rotary valve as well. This is the only reason I can come up with for such ridiculous wear resulting in a clearance that big. Never had any hard-starting issues though, so I'm puzzled. Any thoughts????
    0 Not allowed!
  5. #4
    Join Date
    Nov 2007
    Location
    cape coral fl
    Posts
    1,762
    Watercrafts
    (2) 2003 GTX 4TEC
    Thumbs Up
    Received: 12 Given: 1
    Default
    Is the rotary valve nice and flat or is it warped/bent?
    A warped/bent rotary valve would cause case and valve cover wear.
    0 Not allowed!
  6. #5
    Senior Member
    Join Date
    Sep 2012
    Location
    WA
    Posts
    195
    Watercrafts
    89, 90, 92 XP, 94 XP, 94 SPX, 95 XP, 96 GSX, 96 GTX (all sold) 98 GSX LE, '15 GTS, '15 RXT-X 260
    Thumbs Up
    Received: 2 Given: 0
    Default
    As it was explained to me, the wear is caused over long periods of use due to the edge of the valve itself being the area most likely to flex under constant vacuum and pressure around the ports themselves. Some French guy named Jean Luc told a small group of us that info during advanced technician training in the mid 90's, in Canada.
    This individual also took exception to guys referring to Bombardier as Bomb-a-deer rather than Bombard-ee-ay. One guy called them Bombard-ee-er. Jean Luc yelled "you fools... eet ee-is BOMBARD-EE-AY!"
    0 Not allowed!
  7. ☑ ORIGINAL POSTER #6
    Join Date
    Jun 2012
    Location
    Chicago
    Posts
    10
    Watercrafts
    2013 SeaDoo GTI 130
    Thumbs Up
    Default
    The rotary valve wasn't noticeably warped or bent. However, if the rotary valve and cover have never been replaced in the nearly 12 years this motor has been running, it would be entirely understandable that it would be worn. Might as well replace it and not have to worry.
    I'm hoping a dealer in the area will have one in stock, because that's the final engine component I'm waiting on, and like I said earlier SBT is out of stock.
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Rotary valve cover
    By Richieskis in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-06-13, 10:31 PM
  2. 787 rotary valve cover?
    By Jetskigoodies in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 11-24-12, 12:01 PM
  3. Rotary Shaft Tolerances and Cover Wear
    By Chips in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 07-19-11, 10:30 PM
  4. Rotary Valve Cover
    By SurfBeat in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 08-26-10, 11:33 PM
  5. WTB: Rotary Valve cover (99) RFI
    By olds72 in forum Buy/Sell/Trade Sea-Doo Related
    Last Post: 08-21-10, 07:25 AM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
